10-02-2013 05:37 AM - edited 03-16-2019 07:39 PM
Dear colleagues,
the diagram shows below are originated because a problem with a integration between two PBX, Nortel and Broadsoft through sip trunk, the Nortel PBX forward the uri with the next format:
From: <sip:1607;phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>
But the Broadsoft can´t recongnize the "phone-context=SIP_cdp.SIP_udp", because this we put in the middle a Asterisk PBX, like a bypass, but with the same results, the Asterisk can recognize the "phonecontext=SIP_cdp.SIP_udp" and the call can´t perform.
Nortel says we cannot modify the uri, and Broadsoft says the platform can´t reconize this uri, for all this is the solution with gateways, Colleagues think that can be done the solution shows below?
Dear colleagues, is possible perform this comunication to fix this problem:
10-04-2013 11:29 AM
why h323 between gwA and gwB ? make SIP
otherwise you need cube
