Problems with the IP Phone 9971
Edson Vuma
I have a problem with the CISCO IP Phone 9971.
It started successfully but i have the following issuesÇ
When I press the CONTACT BUTTON, it gives me the following message:
CONTACTS NOT AVAILABLE
Another Issue is that i dont have the CTL and ITL Files.
The security mode that appers on the screen is: Non Secure
LSC: Not installed
My environment is: a router 2951 ISR with CALL MANAGER EXPRESS 8.6 , a switch and the phones.
-- Regards Edson Vuma
2 Accepted Solutions
nikshah
Hi Edson,
Have you configured the directory under voice-register global
eg :- url directory http:///localdirectory
Hope this helps
Niket
Hi Edson,
you are getting this error when you are trying to access directories/contacts right.
if thats the case then you would need to do the following, go to the router and configure the following and see it helps
voice register global
Hope this helps
Niket
Kindly rate all useful posts!!!
8 Replies 8
nikshah
Hi Edson,
Hope this helps
Niket
Thanks for your reply, nikshah.
Im a little bit confused about this.
Would you give me the full command of this configuration?
Hi Edson,
Hope this helps
Niket
Sorry one more time, nikshah.
But, for example.
On this configuration (for 9951):
mode cme
source-address 142.102.66.254 port 5060
max-dn 10
max-pool
load 9951 sip9951.9-1SR1.loads
authenticate register
authenticate realm all
timezone 42
voicemail 4009
tftp-path flash:
file text
create profile sync 0000420080667251
camera
video
How would be the configuration of the directory under voice-register global?
would be like this:
url directory http://<142.102.66.254>/localdirectory
Just to clarify, the command starts with: url directory    , right?
And what is " localdirectory "?
Sorry and thanks for your time.
Thanks...
Let me check if this was the problem
THANK YOU.
It worked perfectly.
Thanks.
And one more thing.
When I connect the CISCO Video Camera on the IP Phone 9971, it gives me a message like:
" CISCO Unified Video Camera has been detected but it is disabled by the administrator"
Did I missed a configuration on the voice register global here?
What would be this command?
One more time, Thanks
Done !!!
The problem was on the voice register global
There where steps missing.
The only thing to do was to enable the CISCO Unified Video Camera by running the following commands>
Router# configure terminal
Router(config)#voice register global
Router(config-register-global)#camera
Router(config-register-global)#video
Router(config-register-global)# create profile
