Problems with WebGUI using CME
uschaefer
When I was logged in as Customer and I try to add another extension to the phone the error msg pop up "Configuration change failed. Please report the following error: Invalid ITS command option". When I do the same and I was logged in as Admin, everything works fine. I tried to change the customer.xml, but it didn?t help. Any ideas?
Cicso2851 with 124-4.XC6, CME 4.0(3) CME-GUI 4.0.3.1
Rob Huffman
Hi Udo,
I would have a look at this setting;
dn-webedit
Example:
Router(config-telephony)# dn-webedit
(Optional) Enables the ability to add directory numbers through the web interface.
The no form of this command disables the ability to create IP phone extension telephone numbers. That ability could disrupt the network wide management of telephone numbers.
If this command is not used, the ability to create directory numbers is disabled by default.
Also check this out;
Creating a Customized XML File for Customer Administrator GUI
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807d5525.html#wp1073152
Hope this helps!
Rob
Hi Rob,
thanks for your response. I fixed the problem. The reason was the XML-file. Some parameters (for example: [Hide | Show] must be "Show". If it is "Hide" you will have the behaviour as I mentioned before.
