Product Specific Configuration Layout_cucm manager 7.5
shohamshalom
hay
i need to change "setting access"  in 1000 cisco phones
the bulk doesn't provide me the solution
the enteprise phone configuration also doesn't provide me the solution
please assist me if u can
tk
shoham
2 Accepted Solutions
Aaron Harrison
When you do the 'query' for the bulk update, select only one phone model at once (e.g. just 7971, or just 7961) and it should show all available settings.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Not one by one, but one phone type at a type, how many different phone types do you have?
Chris
6 Replies 6
Aaron Harrison
Aaron
hay Aaron
that is the problem
i have 1000 phones
do i must change it one by one?
its krazy
Chris
hay
i have 6 different models mix in  4 diferent sites
and i must to do it site by site and not all in once
any idea?
tk man
Rob Huffman
Hi Shoham,
You will require 1 BAT/Update per phone model (not per site) so for
your example you would need to do it 6 times (one per specified model)
To get to the Product Specific settings via Bat, it would be via
an Update with the use of a specific phone model query
So, you would query (for example) 7942's or 7965's and then you can
update the settings you need to.
Cheers!
Rob
thanks man
