10-24-2011 11:10 AM - edited 03-16-2019 07:41 AM
Hi. I haven't had to program this before. I need to program a common number, say 8811, that dials a different destination based on your which building you are in. What's the best practice for this?
10-24-2011 11:15 AM
Maybe mention product and version you're using ?
However, if that's CM, you would use partitions and CSS translations to achieve this.
As with other "advanced" configs, it is recommendable you have a reputable consultant, or Cisco Certified Partner to do it.
10-24-2011 11:18 AM
I apologize. Using CM 8.5.1 SU2.
10-24-2011 12:24 PM
Then as Paolo nicely mentioned all you need are partitions/CSS and translation patterns so that each location reaches a different DN after dialing 8811.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
