Programming Cisco 8861 Lines
AlvaroOdeh1503
Hi Everyone,
I have a cisco 8861 and id like to get information on how to program the 5 available lines?
Am I right in thinking I can have a few different outbound and inbound numbers on the same device?
The idea is to call and receive calls from two different phone numbers on the same device, just like the bluetooth function where it lets you pair your mobile phone and place calls by selecting the mobile phone and dialing a number.
My phone provider can't provide any information and cisco apparently only provide hardware support and not technical support.
I highly appreciate any help in advance, hopefully I can get the full benefits of this phone.
10 Replies 10
George Sotiropoulos
Can you please specify if your phone is registered on a CUCM or CUCME for call-control?
George
Hope the above helps,
gsotirop
I dont believe I have that, my phone provider is Ringcentral who have only
provided the devices.
Please let me know if what I mention is possible and how to make it happen.
Much appreciated your help in advance
Whats the software version on the device?
Thanks.
Unless you've configured Ring Group, then it's not possible.
Not sure on the software version, certainly the firmware has been updated
this morning therefore I believe it would have been updated to the latest
version.
Im unsure as to what ring group is, can I get more info on that or a guide
on how to set it up?
Not sure if you are using a MPP or Enterprise phone. Is your service provider is Ring central?
If you have access to the device webpage you can see the phone version here (for a MPP device):
http://ipaddress/admin/advanced
Info->Status->Product Information->Software Version
On LCD:
Settings->Status->Product Information->Software Version.
Thanks.
I will get that software version in the morning and will post it here.
Yes, my service provider is Ringcentral
I have just checked my software version and it is: sip88xx.11-1-1mpp-897.loads
All I need to configure is a second extension in my same device so I can call and receive calls without the need of having two phones on my desk.
All the help is very much appreciated
Great. So it is a MPP phone. However on a very old firmware which is almost 2 years old. You should first upgrade to 11.2.3MPP.398.
After this you can check if you have access to the device webpage. http://IPADDRESS/admin/advanced.
If you do then you can register upto 10 lines on this phone. On the webpage you will see Ext1 to Ext10 tabs on which you can configure the proxy, userid password etc.
Let me know if you need more help.
Thanks.
HARIS_HUSSAIN
Better to check with phone provider if they support this functionality.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
