Provisioning Manager 9BE - cannot deploy site error
Denis Morin
Have some problems on deploing a BE6K with the Prime Provisioning Manager.
- Under Deployment > Sites, a new site can be created
- After configured "Usage Profiles", clicking on deploy site, I receive the Message "Please check the device status"
Here the next two errors:
Under Deployment > Devices
"CUCM failed with the following error:
Provisioning Route Pattern failed with the following error:
For user IC Administrator, the IPT-0500:Object not Valid"
"CUC failed with the following error:
Provisioning Port failed with the following error:
For user IC Administrator, the IPT-0600:Software"
I have checked Route Pattern -> no entry on the CUCM. The provisionig manager has connection to CUC and CUCM.
Thanks for the help
6 Replies 6
newtonr
Hi Denis, did you ever get this sorted as I have exactly the same issue with UPM-BE?
Unfortunately no, I didn't have the time to investigate further.  I decided to just not use the provisioning manager.
I think it has something to do with only being able to create the Route Patterns if using the NANP and I am using the GBNP dial plan. All other settings are there (CSS/partitions etc).
Rob
Just to let you know I was using NANP and still got the error.
Hi there,
I ran into this issue as well. Let me 1st say that I am running my lab on  UPM v9.0BE with CUCM 9.1.1 and Unity Connection 9.1.1.
The 1st thing to note is that with the v9.1.1 version of Unity Connection, there is a CCO Posted COP file that addresses how UPM v9.0BE does provision VM Ports. I beleive that this is the very issue that I was having.
After applying the COP file to Unity Connection, I then was able to "Deploy Site".  Note however that I did start fresh. i.e: All fresh VM's - non-altered by UPM. I also rebuilt my UPM VM as well (just to be safe). Only then was I able to complete the entire process.    This is my lab environment so I was happy that I took Snapshots at all major stages
Here's the link to the CCO COP File for your reference.  It's the 1st link (License Patch COP File)
http://software.cisco.com/download/release.html?mdfid=284603371&flowid=37563&softwareid=282204704&release=COP-Files&relind=AVAILABLE&rellifecycle=&reltype=latest
Hope this helps!
..Rod
The cop file worked for me. Thanks!
