PSTN calling Issues from 3rd party SIP Phone
bhupendrab
I have a configured a polycom SIP phone in my CCM and able to dial internal extensions but when i try calling PSTN numbers specailly mobile numbers it fails.
CCS and Partition is configured fine and no issues with configuration.
scenario is :
1, When i dial the complete number and go off hook then call gets connected and it works.
2, When i go off hook first and then dial it permits me to dial only 9 or 10 digits not more than that and give me fast busy tone i.e. call fails. can anyone help me in resolving this issue . Might be someone would have faced the same problem.
Thanks in  advance
dijohn
Can you get a wireshark capture from the 3rd party SIP Phone..
Usually this indicated that you have overlapping dial-plans with urgent priority set on a Route-pattern/TP which is shorter than the number you are trying to dial.
Whats the model of the 3rd party SIP phone you are using?.
PS: Rate only useful posts!
