Unity Connection on MCS-7828I3
anis_cisco
Hi all,
I have just did fresh installation of Call Manager Business Edition 6.1 on MCS-7828I3 Server.
I can work perfectly on Call Manager, but Unity Connection seems not working properly.
like, im not able to see add button into users options to add users, also im not able to see add servers options into Port Group to import users from Call Manager, im not able to add new phone system.
Unity Connection version is : 2.1.3ES23.1000-23
I checked the services, all are running ...
attached are the snap shots !!
can any body tell me why im facing this issue ???
anis_cisco
Do i need some license to make unity connection working properly ??
Can any body give suggestion urgently plzz
Hi Anis,
Yes, please install the license files.
Hope this helps,
Justin
www.ucintegrations.com
Hi Justin,
I got the solution, in CUCM B.E we cant add the voicemail users manually. We need to import users from CUCM End Users.
Thats why i was not able to see the add user button in Unity Connection.
Thnxs
