Hi All,
I currently have a customer that is having some trouble calling a into there Cisco IPT system. When an external users calls into the system e.g.456-1234. Some would reach the operator (which is correct) while others would only keep hearing the phone ringing.
The current setup is a follows:
CUCM 7.1
Cisco 2811 IOS 12.4T running MGCP
12 Analog Lines.
Debugs Enabled
Debug voice ccapi inout, vpm signal and mgcp errors.
Telco has verify that the numbers is in a hunt-group
I've notice that when the first caller calls the number (456-1234) it hits the FXO(0/0/0) which is correct port. I get info coming into the router which is correct but when a second user calls the number (456-1234) there hear the phone ringing and I'm not seeing any debug info coming into the router.
Need some help on this. I still believe that the Telco does not have this number in the trunk-group.
Are there anything else I can try?
Any assistance is greatly appreciated.
Adrian
