804
Highlighted
Beginner
PSTN to SIP server
I have a Cisco 2911 i have conf with pstn provider
did translation and created a trunk sip an sent extension to IVR server
but from GSM number when i dial the ivr number it drops like after 8 or more seconds
but when i call directly from a cisco ip phone it passes with no drops
what could be there cause for this
11 REPLIES 11
Highlighted
Engager
What is the exact call flow
What is the exact call flow when you dial number from GSM?
What is the trunk type in gateway?
Do you mean PSTN/GSM -> Cisco Gateway -> SIP Provider ??
Highlighted
Beginner
Pstn provider=CME(2900)=Ivr
Is a trunk sip
Highlighted
Engager
I didn't get you call flow.
I didn't get you call flow. Which trunk you've in CME for PSTN callers to reach CME? FXO or PRI?
Highlighted
Beginner
is a PRI interface Serial0/1
is a PRI
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn incoming-voice voice
 isdn bchan-number-order ascending
 isdn sending-complete
 no cdp enable
dial-peer voice 5077 pots
 description "incoming Calls from CAMTEL-MTN-ORANGE'
 translation-profile incoming INCOMING-CALLS-New
 incoming called-number 5077
 direct-inward-dial
Highlighted
Engager
Can you please share the
Can you please share the output of debug isdn q931 and debug ccsip messages... Also share the output of show run.
Highlighted
Beginner
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 h323
  no call service stop
 sip
voice translation-rule 5
 rule 1 /5077/ /2001/
voice translation-profile INCOMING-CALLS-New
 translate called 5
voice-card 0
controller E1 0/1/0
 clock source internal
 pri-group timeslots 1-31
 no ip address
 encapsulation hdlc
 no cdp enable
voice-port 0/1/0:15
dial-peer voice 5080 voip
 description  IVR
 destination-pattern 2001
 session protocol sipv2
 session target ipv4:192.168.10.1
 dtmf-relay rtp-nte
 codec g711ulaw
 description "From GSM"
 direct-inward-dial
Highlighted
Engager
Hi,I asked you for debugs
I asked you for debugs (isdn q931) and ccsip messages...
Highlighted
Beginner
Ok attached the debug logs
Ok attached the debug logs respectively
Highlighted
VIP Mentor
Divine,The asterisk server is
Divine,
The asterisk server is dropping the call.. You need to investigate why on that side..
Oct  2 15:03:11: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:243223186@192.168.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.1:5060;branch=z9hG4bK66e3e09c;rport
Max-Forwards: 70
To: <sip:243223186@192.168.1.1>;tag=1C3C450-1E1F
Call-ID: 7BCE0AC6-684D11E5-932FDCE6-F497A57D@192.168.1.1
CSeq: 102 BYE
User-Agent: FPBX-12.0.76.1(11.19.0)
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
You may also want to enable PRACK on both asterisk and your voice gateway.
Please rate all useful posts
Highlighted
Beginner
How can this be enable
Highlighted
VIP Mentor
On CUBE you can do it
On CUBE you can do it globally or at the dial-pee level..
voice service voip
  sip
   rel1xx require 100rel
Dial-peer level:
dial-peer voice 1000 voip
  voice-class sip rel1xx require 100rel
I don't know how you enable it on asterisk..You will need to investigate this
