public phone number add name
Ivan Marinovic
is it possible to add a name for the specific public  number. So when I receive a call from that number on my phone I see the name? I did try adding number to the personal directory but name didn't display when i recived call.
I am using CCM 7.1.5
Best regards,
Ivan
Jonathan Schulenberg
CUCM does not have an option to do this natively. You can however use Jabber to query your Outlook contacts and display the name on your computer.
Hi Jonathan,
thank you for fast reply, Unfortunately, this solution is only important on one phone, and the user doesn't use computer :-(
Best regards,
Ivan
Some 3rd party directory options do that, but you would need to discuss with them if your version is compatible as it's pretty old and EOL.
java
if this helps, please rate
Hi, this is also not good solutions because soon we will upgrade to new CUCM and your funds are very limited :-(
