Pulling Record for Multiple DID ranges in Device Pool(s)
Abhishek Singh
We are looking at pulling records for multiple DID ranges for several specific Device Pool(s) -- where the series are like this:
917-212-1xxx  || 917-212-2xxx || 917-212-3xxx || 917-212-4xxx and several others.
Tried using RoutePlan Report but that does not have a Device Pool filter and it pulls out the entire setup // if there has to be a device pool filter somewhere -- known to someone -- would appreciate the help.
Was contemplating using BAT but again -- does run a query with Device Pool -- really exists.
Appreciate a response on this from the bright minds.
Whatever level you reach getting better never stops -- Sachin Tendulkar
brmeade
Level 4
Level 4
You're probably not going to find a filter based on Device Pool for this as the device pool is linked to a device (not patterns).  Just search for the patterns themselves.
