12-12-2013 12:00 PM - edited 03-16-2019 08:50 PM
Hi Everyone,
I am trying to pull a report on daily basis for user with mailboxes from Unity ver 7, We can do it manually from BAT then download the excelsheet
but i am looking to automate this process and schedule it as a daily task. Any help/suggestions appreciated!
Thank you,
Atul
12-12-2013 12:20 PM
Hello Atul,
Reports cannot be scheduled in advanced:
Note that reports cannot be scheduled in advance. If you shut down the Connection or Cisco Unified CMBE server, or close the Connection Administration browser session while reports are being generated, the report generation will be canceled.
The only two task manager options I see regarding Reports are:
Clean Reports Log and Monitor the Size of the Reports Database
-|7A|/i|7
12-12-2013 12:58 PM
You could always try Unity Connection User data dump. It has some scheduling tools that uses the native windows task scheduler.
http://ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
Gareth
