Put incoming call on hold
justin111
We are running Cisco CallManager 4.2 with 7941 and 7961 IP phones and I was wondering if there is a way to place an incoming call directly on hold without having to answer it first.
thanks
justin
gogasca
Level 10
Level 10
Hi Justin,
You can do it with a Contact Center Application (IPCC) or with Attendant Console using Broadcast Hunting Algorithm.
Thanks gogasca, will give the broadcast hunting a try.
justin
mcnerney
Level 4
Level 4
Justin
Another approach that may work for you on an incoming call is to use the IDivert softkey to send the call directly to voicemail.
Larry
Thanks for the response, but I was looking to send callers straight to hold rather than voicemail.
justin
