11-04-2013 02:25 PM - edited 03-16-2019 08:13 PM
Hello
I have c3745 router
It has 2mft-e1, 2mft-t1 and two pvdm-32 on nm module
2mft-t1 on nm module, e1 on onboard wic
I try to create controller
2 t1 is alright (each 5 channel) but 2 e1 cannot create because not enough dsp.
Can I solve this problem?
Sent from Cisco Technical Support Android App
11-04-2013 02:52 PM
Add more dsps or reduce the number of e1 channels..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
11-05-2013 12:40 PM
If you do not want to buy new dsp , check if you have unnecessery media resources configured. Such as confrence bridge or xcoders. You can try removing 1 conf session and it will allow you some channels to configure.
