QoS policy for Nortel phones
jeff_turl
We use Nortel IP phones (1140E), according to the Nortel documentation Voice media is tagged by the phones as DSCP 46 and Signalling as DSCP 40.
Can someone tell me where i have gone wrong! On my switch (3750) i trust the DSCP and have the cos-dscp map set
The router (2621XM) i have the COS-DSCP set, and a service policy.  However when i view the service policy (atm0/0.1) i don't see anything tagged as DSCP 46 only 48:
Switch:
mls qos map cos-dscp 0 8 16 24 32 40 46 56
mls qos
interface r FastEthernet1/0/1 - 48
switchport access vlan 100
switchport mode access
switchport voice vlan 300
priority-queue out
mls qos trust dscp
spanning-tree portfast
Router:
class-map match-any Voice-Media
match ip dscp ef
match ip dscp cs6
class-map match-any Voice-Signalling
match ip dscp cs5
policy-map Torbay_VOIP
class Voice-Media
  priority percent 20
class Voice-Signalling
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface ATM0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0.1 point-to-point
description BT Baseband PREM to Pgn Library
ip address 172.25.200.234 255.255.255.252
cdp enable
pvc 0/32
  vbr-nrt 4378 4378 1
  encapsulation aal5snap
  service-policy output Torbay_VOIP
#sh policy-map interface atm 0/0.1
ATM0/0.1: VC 0/32 -
  Service-policy output: Torbay_VOIP
    Class-map: Voice-Media (match-any)
      80 packets, 14229 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: ip dscp cs6 (48)
        5 minute rate 0 bps
      Queueing
        Strict Priority
        Output Queue: Conversation 136
        Bandwidth 20 (%)
        Bandwidth 875 (kbps) Burst 21875 (Bytes)
        (pkts matched/bytes matched) 80/14229
        (total drops/bytes drops) 0/0
    Class-map: Voice-Signalling (match-any)
      9 packets, 450 bytes
      Match: ip dscp cs5 (40)
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 137
        Bandwidth 5 (%)
        Bandwidth 218 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 1/50
        (depth/total drops/no-buffer drops) 0/0/0
    Class-map: class-default (match-any)
      5735 packets, 3604650 bytes
      5 minute offered rate 234000 bps, drop rate 0 bps
      Match: any
      Queueing
        Flow Based Fair Queueing
        Maximum Number of Hashed Queues 128
        (total queued/total drops/no-buffer drops) 0/0/0
         exponential weight: 9
15 Replies 15
Thanks Alex for all your help, you're a star!
