08-17-2012 08:48 PM - edited 03-16-2019 12:46 PM
i am trying to configuredqsic trunk between cme and panasonic pbx.but the controller is down.here is the show command.
cme#show controllers e1
E1 0/2/0 is down.
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20100222, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
Data in current interval (649 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 649 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
what could be the reason?
thanks
kavi
08-18-2012 12:17 AM
Duplicate post #1.
08-18-2012 01:36 AM
Try different cable and crossover.
08-18-2012 04:31 AM
make CME trunk as master and panasonic as salve , waht you are using here , can you paste show isdn st here . here it alos shows loss of signal , check yr cabling aprt too
rgds
Amim
if this helps, please rate
08-18-2012 04:33 AM
hi,
and make sure you use all 30 channel of E1 ,as sometime it does not worked with fragmneted channel .
rgds
AMim
