I have 3 MCS servers in my telephony cluster1-Pub and 2-SubsEM is only configured on the Pub, if the pub goes off-line, I know the EM feature is gone...Question - Can I run EM on 2 of the 3 servers at the same time?
Everybody say: "you can use SIP instead SCCP but will loose many features"... but nobody said what exactly which features.Im using 10 x 3905 SIP phones and I´m unable to use the hold and transfer buttons. I just put a post asking about this issue, bu...
I'm about to do a 7.x to 8.x upgrade where I am also changing physical servers. I performed a DRS backup of the 7.x server and am planning on importing that into the 8.x server (I have verified that the hop is supported). My questions is about the ...
Hi,A customer has a 2901 with CME 9, ios 15.2. 10xCP-3905 SIP PHONES. all the sip phones are showing wrong time. 5 hours ahead of the router clock.the timezone in the router and the time-zone on voice register global are the same.the firmware for the...
Could you please tell me how to delete the messages in Unity connection 8.x
Has anyone had any luck with a route filter querying a NPA-XXX database for prefixes in a local calling area? I have a good query pointed at localcallingguide.com, but I am looking for a way to update the router filter automatically.Thanks,TJ
I believe the answer is no, but looking to definitive verification – a single Presence server cannot provide this service for multiple clusters, can it? Meaning, the customer is wanting to avoid having to stand up a Presence server in each of four c...
I have a query where we have se calling search spaces set on individual lines where Level1 CSS is for Local users only, Level2 is for Local and National Calls and Level 3 is for Local, Nation and International. We had some thirty users whose CSS on ...
Hi all, this is my first posting here so please bear with me. This is also my first 8.6 installation, and my first UC on UCS installtion. I am trying to install UCM 8.6(2a)SU1, pub and sub, on a UCS C200 M2 running ESXi 5.0. I am not sure if the ESXi...
I need to configure one of our receptionist phones to do a roll over if no one answers. What is the most efficient way to do that?Basically we need our main number to dial in to extension 3612. That part I know how to do. After that though we want...
Hi all,i need a help i want check for the for the quality of conference call from my Cisco 7936 phone,but unable to get the QRT softkey,as i think we cant do thatis there any solution for that
Hi,we've a cluster of CUCM 7.1.3 and customer wants to generate only 1 CDR file per day. We set the CDR File Time Interval to 1440 and now only 1 report per day is generated. THe problem is that this file is generated at 6PM instead of midnight (to h...
Hello all,I have a 2801 router with C2801-advipservicesk9-mz.124-24.T5, CME 7.1 installed and an isdn vic2-2bri-nt/te card.I'm trying to make phone calls with the ephones through and from the isdn line but in both cases i experience one way audio,the...
Hi,Can anyone confirm me what is the codec being used between a Cisco IP phone and Cisco Unity server. Also i want to know what is the minimum bandwidth required for communication between a cisco IP phone and Cisco Unity Server.
Hi.I'm having troubles to download fax offramp tcl scripts.All the references at cisco docs points to this URL for downloading the script:http://www.cisco.com/cgi-bin/tablebuild.pl/tclwareBut when you follow the URL there is no way of downloading the...
Subject | Author | Posted |
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM | ||
07-01-2025 09:51 PM | ||
06-30-2025 02:50 AM |
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
