09-19-2012 10:59 PM - edited 03-16-2019 01:18 PM
i am trying to configure qsic trunk.i couldnt make the connection up.see the debug commands
cme#show isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial0/2/0:15 interface
dsl 6, interface ISDN Switchtype = primary-qsig
**** Slave side configuration ****
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 6 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 214
Total Allocated ISDN CCBs =
cme#debug isdn q931
debug isdn q931 is ON.
UC560#
046568: Sep 20 16:22:29.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046569: Sep 20 16:22:33.440: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 4004
046570: Sep 20 16:22:34.256: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 9520
046571: Sep 20 16:22:38.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046572: Sep 20 16:22:47.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046573: Sep 20 16:22:56.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2debug isdn q931 is ON.
is the qsic trunk up?
09-19-2012 11:20 PM
i have changed the interface serial from user to network.see the config
int serial 0/2/0:15
isdn protocol-emulate network
now
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
UC560#debug isdn q931
UC560#
051918: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 4003
051919: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: Sending SETUP callref = 0x008E callID = 0x801D switch = primary-qsig interface = Network
051920: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x008E
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '4003'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '9520'
051921: Sep 20 21:09:27.771: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x008E
Standard = CCITT
051922: Sep 20 21:09:31.723: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x008D
Cause i = 0x8290 - Normal call clearing
051923: Sep 20 21:09:31.727: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x808D
051924: Sep 20 21:09:33.771: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x008E
Cause i = 0x80E6 - Recovery on timer expiry
UC560#show isdn status
******* Network side configuration *******
**** Master side configuration ****
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Number of L2 Discards = 0, L2 Session ID = 160
Total Allocated ISDN CCBs = 0
still i couldnt make call
09-20-2012 06:01 PM
now can able to call from cisco to nec pbx.but couldnt call from nec pbx to cisco.see the debug when call made from nec to cisco.
cme#debug isdn error
cme#
052409: Sep 20 23:33:25.351: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
09-20-2012 09:37 PM
That only indicates a condition not a general error.
You have to look at the complete q031 trace to understand what happens.
