qsig trunk between cme and nec pbx
tkavithas87
i am trying to configure qsic trunk.i couldnt make the connection up.see the debug commands
cme#show isdn status
Global ISDN Switchtype = primary-qsig
ISDN Serial0/2/0:15 interface
        dsl 6, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 6 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 214
    Total Allocated ISDN CCBs =
cme#debug isdn q931
debug isdn q931 is              ON.
UC560#
046568: Sep 20 16:22:29.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046569: Sep 20 16:22:33.440: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 4004
046570: Sep 20 16:22:34.256: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Called num 9520
046571: Sep 20 16:22:38.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046572: Sep 20 16:22:47.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
046573: Sep 20 16:22:56.256: ISDN Se0/2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2debug isdn q931 is              ON.
is the qsic trunk  up?
tkavithas87
i have changed the interface serial from user to network.see the config
int serial 0/2/0:15
isdn protocol-emulate network
now
Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
UC560#debug isdn q931
UC560#
051918: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 4003
051919: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x008E callID = 0x801D switch = primary-qsig interface = Network
051920: Sep 20 21:09:21.771: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008E
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '4003'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '9520'
051921: Sep 20 21:09:27.771: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008E
                Standard = CCITT
051922: Sep 20 21:09:31.723: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x008D
        Cause i = 0x8290 - Normal call clearing
051923: Sep 20 21:09:31.727: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808D
051924: Sep 20 21:09:33.771: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x008E
        Cause i = 0x80E6 - Recovery on timer expiry
UC560#show isdn status
        ******* Network side configuration *******
         **** Master side configuration ****
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Number of L2 Discards = 0, L2 Session ID = 160
    Total Allocated ISDN CCBs = 0
still i couldnt make call
now can able to call from cisco to nec pbx.but couldnt call from nec pbx to cisco.see the debug when call made from nec to cisco.
cme#debug isdn error
cme#
052409: Sep 20 23:33:25.351: ISDN Se0/2/0:15 SERROR: process_pri_simple: NO name in GTD
That only indicates a condition not a general error.
You have to look at the complete q031 trace to understand what happens.
