IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5907 Views
  • 14 replies
                   Hello,Can anyone point me to a link that shows all the specs (memory, CPU, disk space) required to run install 8.6 directly (not a bridged upgrade) onto an HP server? So far all I can find is that the HP Proliant G5 should work but...
Resolved! 8945 DnD alert
Running firmware SIP8941_8945.9-3-1-18When the DND softkey is pressed, a popup appears notifiing you that it is either enabled or disabled. Then it dissapears. There is nothing else to signal that DND is enabled, unlike on the 79XX where there is tex...
I have two connection ,one PRI and an Analog connection(fxo).I want all users to use PRI DID number except receptionist.I want Receptionist to take analog line for both incoming and outgoing call.In coming is coming to recetionist extension 0.But wh...
