03-11-2014 08:34 AM - edited 03-16-2019 10:05 PM
In reading info around the web, I do find and understand that any changes made to configuration of an upgraded CUCM node will be lost if they were made after upgrade but before switch-version. I was wondering if CDR files/database were also grouped into this, or if those are copied over when switch-version is executed.
Solved! Go to Solution.
03-11-2014 10:04 PM
CDR records will be lost, only user facing features are preserved. Please check the following post
https://supportforums.cisco.com/discussion/11117171/cucm-upgrade-and-cdr-records#3293654
Manish
03-11-2014 10:04 PM
Manish
03-12-2014 04:29 AM
Thanks Manish. Do you know if there's a similar write-up for Unity Connection? I already know UCCX loses everything, based on experience.
03-12-2014 10:22 AM
Please check the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrugx/8xcucrug015.html
Manish
03-12-2014 10:51 AM
Wow, that's a lengthy read. Tnanks for the pointer, I'll have to set aside some time to process through that one.
