questions on route group
karthik ratna
MGCP gateway
Route group distribution: Top down
In this type, calls will go to top to down , i.e.., covering all 30 channels in E1 line and passing to another E1 line, is it correct?
If yes, how to change the behaviour to pass a first call to 1E1 line and next call to another E1 line, is their any parameters to change to achive this?
Please guide.
Harmit Singh
Hi Karthik,
Did you take a look at circular distribution algorithm?
  • Top Down—If you choose this distribution  algorithm, Cisco Unified Communications Manager distributes a call to  idle or available members starting from the first idle or available  member of a route group to the last idle or available member.
  • Circular—If you  choose this distribution algorithm, Cisco Unified Communications Manager  distributes a call to idle or available members starting from the (n+1)th member of a route group, where the nth member is the member to which Cisco Unified Communications Manager most recently extended a call. If the nth  member is the last member of a route group, Cisco Unified  Communications Manager distributes a call starting from the top of the  route group.
  • HTH.
    Harmit.
    I think karthik is looking for a load-balancing between E1s. If that is the case you can use: distribution  Algorithm-> Longest Idle Time.
    Please rate all useful posts
    _____________________________
    MDGDP, CCNA, CCNA Voice certified
    __________________________________________________
    Please remember to rate useful posts clicking on the stars below.
    LinkedIn Profile: do.linkedin.com/in/leosalcie
    Harmit Singh
    Hi leosalcie,
    I think you are referring to hunt group and not route group :-) There is no such option for route groups.
    Harmit.
