Showing results forĀ
Search instead forĀ
Did you mean:Ā
Queues on CCX Supervisor 7.0(1)SR05_Build504
Marcos Cardoso
Hi all,
I Have a situation that the queues on the supervisor agent desktop are not restarting. This it means that when the supervisor“s logged on the they are gotting the numbers of the day before and so on. I have been found some information, but in documentation Cisco does not explation how to solve this problem.
Anybody knows how to solve it?
I will appreciate any further help!
Marcos Cardoso
anchoudh
Level 9
Level 9
HI Marcos,
Do you mean that Supersiors are seeing only thats days data on CSD?
Voice CSQ – Detail
The Voice CSQ—Detail display is available when you select a specific CSQ from the Skill Groups tree. This display presents information about each agent logged into the ACD and assigned  to the selected CSQ. By default, the data displayed is sorted in ascending order by agent name.
The data is obtained from the CAD Chat service, and are for the current day starting at
midnight. The data refresh rate is 1 second, and is not configurable.
Voice CSQ – Summary
The CSQ — Summary display is available when you select a specific CSQ from the Skill Groups tree.
This display presents a summary of a specific CSQ’s statistics. These statistics are from the entire contact center, not just from members of the selected team.
The data is obtained from the CTI server unless otherwise noted, and are for the current day starting at midnight. The data refresh rate is configurable and ranges from every 5 to 60 seconds. By default it is every 15 seconds.
Voice CSQs – Team Summary
The Team Summary display is available when you select the Skill Groups node in the Skill Groups tree. This display presents the details of each individual skill group, regardless of whether or not an agent with that skill is logged in. By default, the data displayed is sorted in ascending order by skill name.
Please refer the below link for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/user/guide/csd85ccxug-cm.pdf
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
