09-21-2016 01:40 AM - edited 03-17-2019 08:08 AM
Hi all,
I want to create 6 vlan voice in CME, so i should create 6 dhcp pool my archetecture is like that:
so i will create 6 dhcp pool like that:
ip dhcp pool vlan1
network 10.100.1.0 255.255.255.0
option ip 10.100.100.1
default-router 10.100.1.1
ip dhcp pool vlan2
network 10.100.2.0 255.255.255.0
default-router 10.100.2.1
ip dhcp pool vlan3
network 10.100.3.0 255.255.255.0
default-router 10.100.3.1
ip dhcp pool vlan4
network 10.100.4.0 255.255.255.0
default-router 10.100.4.1
ip dhcp pool vlan5
network 10.100.5.0 255.255.255.0
default-router 10.100.5.1
ip dhcp pool vlan6
network 10.100.6.0 255.255.255.0
default-router 10.100.6.1
but i don't know which IP address i should put for "ip source-address" in telephony-service
Solved! Go to Solution.
09-21-2016 02:42 AM
Example
int lo0
ip add 150.1.1.1 255.255.255.255
telephony-service
ip source-add 150.1.1.1
09-21-2016 01:58 AM
which one is the voice vlan. Use its IP.
09-21-2016 02:05 AM
Thanks Mohamed,
the all 6 vlan are voice IP, because i want to use one IPBX CME for many department each departement has his VLAN voice.
MM
09-21-2016 02:24 AM
Best is to create loopback and use it as source address
09-21-2016 02:31 AM
so how i can creat it in my case?
09-21-2016 02:42 AM
Example
int lo0
telephony-service
09-21-2016 02:46 AM
thank you a lot Mohamed
10-11-2016 02:08 AM
Hi Mohamed,
I test that but the ip phones is always on registering case
My config is like is:
ip dhcp pool TC-Voice
network 100.30.60.0 255.255.255.0
default-router 100.30.60.1
option 150 ip 100.30.60.1
int loopback 0
ip address 192.168.0.1 255.255.255.0
voice register global
mode cme
source-address 192.168.0.1 port 5060
timeouts interdigit 3
max-dn 600
max-pool 260
create profile sync 0006586737825072
thnks
ragards,
10-11-2016 03:24 AM
Hi Moussa,
option 150 ip should be the IP address of your TFTP server which can give the CME info for the phones to register.
Can you try changing that to 192.168.0.1, do "create profile" in Voice register global and reset the phones.
Rajan
10-11-2016 03:44 AM
Hi Rajan thanks for your reply,
I tried that but not working
MM
10-11-2016 04:21 AM
my full config:
MZZٳgf͔config-dial-peer)# destination-pattern .T
PJM-3925(config-dial-peer)#exit
PJM-3925(config)#sh runn
% Invalid input detected at '^' marker.
PJM-3925(config)#exit
PJM-3925#s
*Oct 11 11:19:08.763: %SYS-5-CONFIG_I: Configured from console by admin on conso leh runn
PJM-3925#sh running-config
Building configuration...
Current configuration : 39188 bytes
! Last configuration change at 11:19:08 UTC Tue Oct 11 2016 by admin
version 15.4
hostname PJM-3925
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
no aaa new-model
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 100.30.60.1
option 150 ip 100.30.0.1
ip domain name yourdomain.com
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-554244252
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-554244252
revocation-check none
rsakeypair TP-self-signed-554244252
crypto pki certificate chain TP-self-signed-554244252
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 35353432 34343235 32301E17 0D313630 39313231 32343131
345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3535 34323434
32353230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
C8713650 D3914D38 D6F40E8A B8616819 CB2C1AC4 EF21FCB9 69D69FB4 A0C9C3EB
B9923926 DD27E356 1524F9BF C50D8B2F C2D117B0 12CFA30B 67F38493 AD05B50A
EA71A9CE F3C318A9 BF137221 B288597F 9259DAF3 5068E99E F297955C 0C0DDE07
F7FD1F25 D0DAEB18 E525EDD4 D33D9E7C 0503CE60 B5C0E3FD 345CA032 FB4624C1
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 16801442 B8459256 03A96184 EE10FB51 2CECA55D 12811D30 1D060355
1D0E0416 041442B8 45925603 A96184EE 10FB512C ECA55D12 811D300D 06092A86
4886F70D 01010505 00038181 0068E822 927EA077 A4E9D9C1 FFED333F A641A14E
E02B045F EEE4EF39 B7EBEA9E 7CE79959 98F9C0B9 98A3F1E4 15DC2DFE D57FEABB
7C8C0814 39732E72 C935839D CA17FC7B 71AB04B9 169D1CC2 9F0FF352 86DA58A6
D348FAA9 837298E4 D4689600 DDD5F77C 24B21BA4 DE8A7426 C5A81206 717E4F66
EB86443E 38E2351A 2D5A9660 6D
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 1200 min 300
voice register pool-type 8851
xml-config maxNumCalls 6
xml-config busyTrigger 2
num-lines 77
addons 2
description Cisco IP Phone 8851
reference-pooltype 9951
mode cme
source-address 100.30.0.1 port 5060
max-dn 600
max-pool 260
create profile sync 0011306126545006
voice register dn 1
number 1001
name phone 1
voice register dn 2
number 1002
name phone 2
voice register dn 3
number 1003
name phone 3
voice register dn 4
number 1004
name phone 4
voice register dn 5
number 1005
name phone 5
voice register dn 6
number 1006
name phone 6
voice register dn 7
number 1007
name phone 7
voice register dn 8
number 1008
name phone 8
voice register dn 9
number 1009
name phone 9
voice register dn 10
number 1010
name phone 10
voice register dn 11
number 1011
name phone 11
voice register dn 12
number 1012
name phone 12
voice register dn 13
number 1013
name phone 13
voice register dn 14
number 1014
name phone 14
voice register dn 15
number 1015
name phone 15
voice register dn 16
number 1016
name phone 16
voice register dn 17
number 1017
name phone 17
voice register dn 18
number 1018
name phone 18
voice register dn 19
number 1019
name phone 19
voice register dn 20
number 1020
name phone 20
voice register dn 21
number 1021
name phone 21
voice register dn 22
number 1022
name phone 22
voice register dn 23
number 1023
name phone 23
voice register dn 24
number 1024
name phone 24
voice register dn 25
number 1025
name phone 25
voice register dn 26
number 1026
name phone 26
voice register dn 27
number 1027
name phone 27
voice register dn 28
number 1028
name phone 28
voice register dn 29
number 1029
name phone 29
voice register dn 30
number 1030
name phone 30
voice register dn 31
number 1031
name phone 31
voice register dn 32
number 1032
name phone 32
voice register dn 33
number 1033
name phone 33
voice register dn 34
number 1034
name phone 34
voice register dn 35
number 1035
name phone 35
voice register dn 36
number 1036
name phone 36
voice register dn 37
number 1037
name phone 37
voice register dn 38
number 1038
name phone 38
voice register dn 39
number 1039
name phone 39
voice register dn 40
number 1040
name phone 40
voice register dn 41
number 1041
name phone 41
voice register dn 42
number 1042
name phone 42
voice register dn 43
number 1043
name phone 43
voice register dn 44
number 1044
name phone 44
voice register dn 45
number 1045
name phone 45
voice register dn 46
number 1046
name phone 46
voice register dn 47
number 1047
name phone 47
voice register dn 48
number 1048
name phone 48
voice register dn 49
number 1049
name phone 49
voice register dn 50
number 1050
name phone 50
voice register dn 51
number 1051
name phone 51
voice register dn 52
number 1052
name phone 52
voice register dn 53
number 1053
name phone 53
voice register dn 54
number 1054
name phone 54
voice register dn 55
number 1055
name phone 55
voice register dn 56
number 1056
name phone 56
voice register dn 57
number 1057
name phone 57
voice register dn 58
number 1058
name phone 58
voice register dn 59
number 1059
name phone 59
voice register dn 60
number 1060
name phone 60
voice register dn 61
number 1061
name phone 61
voice register dn 62
number 1062
name phone 62
voice register dn 63
number 1063
name phone 63
voice register dn 64
number 1064
name phone 64
voice register dn 65
number 1065
name phone 65
voice register dn 66
number 1066
name phone 66
voice register dn 67
number 1067
name phone 67
voice register dn 68
number 1068
name phone 68
voice register dn 69
number 1069
name phone 69
voice register dn 70
number 1070
name phone 70
voice register dn 71
number 1071
name phone 71
voice register dn 72
number 1072
name phone 72
voice register dn 73
number 1073
name phone 73
voice register dn 74
number 1074
name phone 74
voice register dn 75
number 1075
name phone 75
voice register dn 76
number 1076
name phone 76
voice register dn 77
number 1077
name phone 77
voice register dn 78
number 1078
name phone 78
voice register dn 79
number 1079
name phone 79
voice register dn 80
number 1080
name phone 80
voice register dn 81
number 1081
name phone 81
voice register dn 82
number 1082
name phone 82
voice register dn 83
number 1083
name phone 83
voice register dn 84
number 1084
name phone 84
voice register dn 85
number 1085
name phone 85
voice register dn 86
number 1086
name phone 86
voice register dn 87
number 1087
name phone 87
voice register dn 88
number 1088
name phone 88
voice register dn 89
number 1089
name phone 89
voice register dn 90
number 1090
name phone 90
voice register dn 91
number 1091
name phone 91
voice register dn 92
number 1092
name phone 92
voice register dn 93
number 1093
name phone 93
voice register dn 94
number 1094
name phone 94
voice register dn 95
number 1095
name phone 95
voice register dn 96
number 1096
name phone 96
voice register dn 97
number 1097
name phone 97
voice register dn 98
number 1098
name phone 98
voice register dn 99
number 1099
name phone 99
voice register dn 100
number 1100
name phone 100
voice register dn 101
number 1101
name phone 101
voice register dn 102
number 1102
name phone 102
voice register dn 103
number 1103
name phone 103
voice register dn 104
number 1104
name phone 104
voice register dn 105
number 1105
name phone 105
voice register dn 106
number 1106
name phone 106
voice register dn 107
number 1107
name phone 107
voice register dn 108
number 1108
name phone 108
voice register dn 109
number 1109
name phone 109
voice register dn 110
number 1110
name phone 110
voice register dn 111
number 1111
name phone 111
voice register dn 112
number 1112
name phone 112
voice register dn 113
number 1113
name phone 113
voice register dn 114
number 1114
name phone 114
voice register dn 115
number 1115
name phone 115
voice register dn 116
number 1116
name phone 116
voice register dn 117
number 1117
name phone 117
voice register dn 118
number 1118
name phone 118
voice register dn 119
number 1119
name phone 1119
voice register dn 120
number 1120
name phone 120
voice register dn 121
number 1121
name phone 121
voice register dn 122
number 1122
name phone 122
voice register dn 123
number 1123
name phone 123
voice register dn 124
number 1124
name phone 124
voice register dn 125
number 1125
name phone 125
voice register dn 126
number 1126
name phone 126
voice register dn 127
number 1127
name phone 127
voice register dn 128
number 1128
name phone 128
voice register dn 129
number 1129
name phone 129
voice register dn 130
number 1130
name phone 130
voice register dn 131
number 1131
name phone 131
voice register dn 132
number 1132
name phone 132
voice register dn 133
number 1133
name phone 133
voice register dn 134
number 1134
name phone 134
voice register dn 135
number 1135
name phone 135
voice register dn 136
number 1136
name phone 136
voice register dn 137
number 1137
name phone 137
voice register dn 138
number 1138
name phone 138
voice register dn 139
number 1139
name phone 139
voice register dn 140
number 1140
name phone 140
voice register dn 141
number 1141
name phone 141
voice register dn 142
number 1142
name phone 142
voice register dn 143
number 1143
name phone 143
voice register dn 144
number 1144
name phone 144
voice register dn 145
number 1145
name phone 145
voice register dn 146
number 1146
name phone 146
voice register dn 147
number 1147
name phone 147
voice register dn 148
number 1148
name phone 148
voice register dn 149
number 1149
name phone 149
voice register dn 150
number 1150
name phone 150
voice register dn 151
number 1151
name phone 151
voice register dn 152
number 1152
name phone 152
voice register dn 153
number 1153
name phone 153
voice register dn 154
number 1154
name phone 154
voice register dn 155
number 1155
name phone 155
voice register dn 156
number 1156
name phone 156
voice register dn 157
number 1157
name phone 157
voice register dn 158
number 1158
name phone 158
voice register dn 159
number 1159
name phone 159
voice register dn 160
number 1160
name phone 160
voice register dn 161
number 1161
name phone 161
voice register dn 162
number 1162
name phone 162
voice register dn 163
number 1163
name phone 163
voice register dn 164
number 1164
name phone 164
voice register dn 165
number 1165
name phone 165
voice register dn 166
number 1166
name phone 166
voice register dn 167
number 1167
name phone 167
voice register dn 168
number 1168
name phone 168
voice register dn 169
number 1169
name phone 169
voice register dn 170
number 1170
name phone 170
voice register dn 171
number 1171
name phone 171
voice register dn 172
number 1172
name phone 172
voice register dn 173
number 1173
name phone 173
voice register dn 174
number 1174
name phone 174
voice register dn 175
number 1175
name phone 175
voice register dn 176
number 1176
name phone 176
voice register dn 177
number 1177
name phone 177
voice register dn 178
number 1178
name phone 178
voice register dn 179
number 1179
name phone 179
voice register dn 180
number 1180
name phone 180
voice register pool 1
id mac 0C11.6763.A852
type 8851
number 1 dn 1
username user1 password cisco
voice register pool 2
id mac 0C11.6763.8E84
type 8851
number 1 dn 2
username user2 password cisco
voice register pool 3
id mac 0C11.6762.E1EC
type 8851
number 1 dn 3
username user3 password cisco
voice register pool 4
id mac 0C11.6762.FC5A
type 8851
number 1 dn 4
username user4 password cisco
voice register pool 5
id mac 0C11.6763.DB6E
type 8851
number 1 dn 5
username user5 password cisco
voice register pool 6
id mac 0C11.6763.6966
type 8851
number 1 dn 6
username user6 password cisco
voice register pool 7
id mac 0C11.6763.C610
type 8851
number 1 dn 7
username user7 password cisco
voice register pool 8
id mac 0C11.6763.D440
type 8851
number 1 dn 8
username user8 password cisco
voice register pool 9
id mac 0C11.6763.5B06
type 8851
number 1 dn 9
username user9 password cisco
voice register pool 10
id mac 0C11.6763.9ED6
type 8851
number 1 dn 10
username user10 password cisco
voice register pool 11
id mac 0C11.6763.557E
type 8851
number 1 dn 11
username user11 password cisco
voice register pool 12
id mac 0C11.6763.B172
type 8851
number 1 dn 12
username user12 password cisco
voice register pool 13
id mac 0C11.6763.B162
type 8851
number 1 dn 13
username user13 password cisco
voice register pool 14
id mac 00CC.FC40.099A
type 8851
number 1 dn 14
username user14 password cisco
voice register pool 15
id mac 0C11.6763.A270
type 8851
number 1 dn 15
username user15 password cisco
voice register pool 16
id mac 0C11.6763.AB0A
type 8851
number 1 dn 16
username user16 password cisco
voice register pool 17
id mac 0C11.6763.9E1A
type 8851
number 1 dn 17
username user17 password cisco
voice register pool 18
id mac 0C11.6763.D9A0
type 8851
number 1 dn 18
username user18 password cisco
voice register pool 19
id mac 0C11.6763.D7EA
type 8851
number 1 dn 19
username user19 password cisco
voice register pool 20
id mac 0C11.6762.E7C2
type 8851
number 1 dn 20
username user20 password cisco
voice register pool 21
id mac 0C11.6763.F9A0
type 8851
number 1 dn 21
username user21 password cisco
voice register pool 22
id mac 0C11.6763.E612
type 8851
number 1 dn 22
username user22 password cisco
voice register pool 23
id mac 0C11.6763.BD8A
type 8851
number 1 dn 23
username user23 password cisco
voice register pool 24
id mac 0C11.6763.87A4
type 8851
number 1 dn 24
username user24 password cisco
voice register pool 25
id mac 0C11.6763.D4E4
type 8851
number 1 dn 25
username user25 password cisco
voice register pool 26
id mac 0C11.6763.CF82
type 8851
number 1 dn 26
username user26 password cisco
voice register pool 27
id mac 0C11.6763.5816
type 8851
number 1 dn 27
username user27 password cisco
voice register pool 28
id mac 0C11.6763.DA62
type 8851
number 1 dn 28
username user28 password cisco
voice register pool 29
id mac 00CC.FC40.0832
type 8851
number 1 dn 29
username user29 password cisco
voice register pool 30
id mac 0C11.6763.186A
type 8851
number 1 dn 30
username user30 password cisco
voice register pool 31
busy-trigger-per-button 2
id mac 0041.D2B2.C39E
type 7841
number 1 dn 31
username user31 password cisco
voice register pool 32
id mac 0041.D2B2.C36A
type 7841
number 1 dn 32
username user32 password cisco
voice register pool 33
id mac 0041.D2B2.C300
type 7841
number 1 dn 33
username user33 password cisco
voice register pool 34
id mac 0041.D2B2.C22D
type 7841
number 1 dn 34
username user34 password cisco
voice register pool 35
id mac 0041.D2B2.C4DC
type 7841
number 1 dn 35
username user35 password cisco
voice register pool 36
id mac 0041.D2B2.C287
type 7841
number 1 dn 36
username user36 password cisco
voice register pool 37
id mac 0041.D2B2.C280
type 7841
number 1 dn 37
username user37 password cisco
voice register pool 38
id mac 0041.D2B2.C208
type 7841
number 1 dn 38
username user38 password cisco
voice register pool 39
id mac 0041.D2B2.C372
type 7841
number 1 dn 39
username user39 password cisco
voice register pool 40
id mac 0041.D2B2.C1E1
type 7841
number 1 dn 40
username user40 password cisco
voice register pool 41
id mac 00EB.D5E7.ECB8
type 7841
number 1 dn 41
username user41 password cisco
voice register pool 42
id mac 00EB.D5E7.EBA9
type 7841
number 1 dn 42
username user42 password cisco
voice register pool 43
id mac 00EB.D5E7.EB4A
type 7841
number 1 dn 43
username user43 password cisco
voice register pool 44
id mac 00EB.D5E7.EB1D
type 7841
number 1 dn 44
username user44 password cisco
voice register pool 45
id mac 00EB.D5E7.EB15
type 7841
number 1 dn 45
username user45 password cisco
voice register pool 46
id mac 00EB.D5E7.EB60
type 7841
number 1 dn 46
username user46 password cisco
voice register pool 47
id mac 00EB.D5E7.EA04
type 7841
number 1 dn 47
username user47 password cisco
voice register pool 48
id mac 00EB.D5E7.EB4F
type 7841
number 1 dn 48
username user48 password cisco
voice register pool 49
id mac 00EB.D5E7.EB57
type 7841
number 1 dn 49
username user49 password cisco
voice register pool 50
id mac 00EB.D5E7.EBA3
type 7841
number 1 dn 50
username user50 password cisco
voice register pool 51
id mac 0041.D2B2.C2F6
type 7841
number 1 dn 51
username user51 password cisco
voice register pool 52
id mac 0041.D2B2.C2EE
type 7841
number 1 dn 52
username user52 password cisco
voice register pool 53
id mac 0041.D2B2.C3B6
type 7841
number 1 dn 53
username user53 password cisco
voice register pool 54
id mac 0041.D2B2.C36F
type 7841
number 1 dn 54
username user54 password cisco
voice register pool 55
id mac 0041.D2B2.C39D
type 7841
number 1 dn 55
username user55 password cisco
voice register pool 56
id mac 0041.D2B2.C32C
type 7841
number 1 dn 56
username user56 password cisco
voice register pool 57
id mac 0041.D2B2.C3C9
type 7841
number 1 dn 57
username user57 password cisco
voice register pool 58
id mac 0041.D2B2.C26E
type 7841
number 1 dn 58
username user58 password cisco
voice register pool 59
id mac 0041.D2B2.C337
type 7841
number 1 dn 59
username user59 password cisco
voice register pool 60
id mac 0041.D2B2.C33A
type 7841
number 1 dn 60
username user60 password cisco
voice register pool 61
id mac 0041.D2B3.B844
type 7841
number 1 dn 61
username user61 password cisco
voice register pool 62
id mac 0041.D2B3.B8EA
type 7841
number 1 dn 62
username user62 password cisco
voice register pool 63
id mac 0041.D2B3.B8A2
type 7841
number 1 dn 63
username user63 password cisco
voice register pool 64
id mac 0041.D2B3.B8CC
type 7841
number 1 dn 64
username user64 password cisco
voice register pool 65
id mac 0041.D2B3.B89A
type 7841
number 1 dn 65
username user65 password cisco
voice register pool 66
id mac 0041.D2B3.B845
type 7841
number 1 dn 66
username user66 password cisco
voice register pool 67
id mac 0041.D2B3.B8DC
type 7841
number 1 dn 67
username user67 password cisco
voice register pool 68
id mac 0041.D2B3.B8F1
type 7841
number 1 dn 68
username user68 password cisco
voice register pool 69
id mac 0041.D2B3.B8B0
type 7841
number 1 dn 69
username user69 password cisco
voice register pool 70
id mac 0041.D2B3.B90E
type 7841
number 1 dn 70
username user70 password cisco
voice register pool 71
id mac 0041.D2B3.B6D2
type 7841
number 1 dn 71
username user71 password cisco
voice register pool 72
id mac 0041.D2B3.B5F8
type 7841
number 1 dn 72
username user72 password cisco
voice register pool 73
id mac 0041.D2B3.B66D
type 7841
number 1 dn 73
username user73 password cisco
voice register pool 74
id mac 0041.D2B3.B60A
type 7841
number 1 dn 74
username user74 password cisco
voice register pool 75
id mac 0041.D2B3.B6BE
type 7841
number 1 dn 75
username user75 password cisco
voice register pool 76
id mac 0041.D2B3.B778
type 7841
number 1 dn 76
username user76 password cisco
voice register pool 77
id mac 0041.D2B3.B695
type 7841
number 1 dn 77
username user77 password cisco
voice register pool 78
id mac 0041.D2B3.B70F
type 7841
number 1 dn 78
username user78 password cisco
voice register pool 79
id mac 0041.D2B3.B7E1
type 7841
number 1 dn 79
username user79 password cisco
voice register pool 80
id mac 0041.D2B3.B682
type 7841
number 1 dn 80
username user80 password cisco
voice register pool 81
id mac 00EB.D5E7.EB20
type 7841
number 1 dn 81
username user81 password cisco
voice register pool 82
id mac 00EB.D5E7.EB5F
type 7841
number 1 dn 82
username user82 password cisco
voice register pool 83
id mac 00EB.D5E7.EB56
type 7841
number 1 dn 83
username user83 password cisco
voice register pool 84
id mac 00EB.D5E7.EB47
type 7841
number 1 dn 84
username user84 password cisco
voice register pool 85
id mac 00EB.D5E7.EB9F
type 7841
number 1 dn 85
username user85 password cisco
voice register pool 86
id mac 00EB.D5E7.EB4D
type 7841
number 1 dn 86
username user86 password cisco
voice register pool 87
id mac 00EB.D5E7.ED2F
type 7841
number 1 dn 87
username user87 password cisco
voice register pool 88
id mac 00EB.D5E7.EBA4
type 7841
number 1 dn 88
username user88 password cisco
voice register pool 89
id mac 00EB.D5E7.EADD
type 7841
number 1 dn 89
username user89 password cisco
voice register pool 90
id mac 00EB.D5E7.EB7F
type 7841
number 1 dn 90
username user90 password cisco
voice register pool 91
id mac 0041.D2B3.BD76
type 7841
number 1 dn 91
username user91 password cisco
voice register pool 92
id mac 0041.D2B3.BC41
type 7841
number 1 dn 92
username user92 password cisco
voice register pool 93
id mac 0041.D2B3.B900
type 7841
number 1 dn 93
username user93 password cisco
voice register pool 94
id mac 0041.D2B3.B87A
type 7841
number 1 dn 94
username user94 password cisco
voice register pool 95
id mac 0041.D2B3.B893
type 7841
number 1 dn 95
username user95 password cisco
voice register pool 96
id mac 0041.D2B3.BC34
type 7841
number 1 dn 96
username user96 password cisco
voice register pool 97
id mac 0041.D2B3.B8B4
type 7841
number 1 dn 97
username user97 password cisco
voice register pool 98
id mac 0041.D2B3.B836
type 7841
number 1 dn 98
username user98 password cisco
voice register pool 99
id mac 0041.D2B3.B90A
type 7841
number 1 dn 99
username user99 password cisco
voice register pool 100
id mac 0041.D2B3.B8B5
type 7841
number 1 dn 100
username user100 password cisco
voice register pool 101
id mac 0041.D2B2.C29A
type 7841
number 1 dn 101
username user101 password cisco
voice register pool 102
id mac 0041.D2B2.C5F4
type 7841
number 1 dn 102
username user102 password cisco
voice register pool 103
id mac 0041.D2B2.C27B
type 7841
number 1 dn 103
username user103 password cisco
voice register pool 104
id mac 0041.D2B2.C25C
type 7841
number 1 dn 104
username user104 password cisco
voice register pool 105
id mac 0041.D2B2.C2D1
type 7841
number 1 dn 105
username user105 password cisco
voice register pool 106
id mac 00EB.D5E7.EAC3
type 7841
number 1 dn 106
username user106 password cisco
voice register pool 107
id mac 00EB.D5E7.EAE3
type 7841
number 1 dn 107
username user107 password cisco
voice register pool 108
id mac 00EB.D5E7.EB23
type 7841
number 1 dn 108
username user108 password cisco
voice register pool 109
id mac 00EB.D5E7.EB10
type 7841
number 1 dn 109
username user109 password cisco
voice register pool 110
id mac 00EB.D5E7.EC75
type 7841
number 1 dn 110
username user110 password cisco
voice register pool 111
id mac 00EB.D5E7.EAEA
type 7841
number 1 dn 111
username user111 password cisco
voice register pool 112
id mac 00EB.D5E7.EAEB
type 7841
number 1 dn 112
username user112 password cisco
voice register pool 113
id mac 00EB.D5E7.EAFB
type 7841
number 1 dn 113
username user113 password cisco
voice register pool 114
id mac 00EB.D5E7.EA00
type 7841
number 1 dn 114
username user114 password cisco
voice register pool 115
id mac 00EB.D5E7.EB48
type 7841
number 1 dn 115
username user115 password cisco
voice register pool 116
id mac 0041.D2B2.C5E2
type 7841
number 1 dn 116
username user116 password cisco
voice register pool 117
id mac 0041.D2B2.C5DA
type 7841
number 1 dn 117
username user117 password cisco
voice register pool 118
id mac 0041.D2B2.C28E
type 7841
number 1 dn 118
username user118 password cisco
voice register pool 119
id mac 0041.D2B2.CB0F
type 7841
number 1 dn 119
username user119 password cisco
voice register pool 120
id mac 0041.D2B2.C295
type 7841
number 1 dn 120
username user120 password cisco
voice register pool 121
id mac 0041.D2B2.C322
type 7841
number 1 dn 121
username user121 password cisco
voice register pool 122
id mac 0041.D2B2.C2A3
type 7841
number 1 dn 122
username user122 password cisco
voice register pool 123
id mac 0041.D2B2.C392
type 7841
number 1 dn 123
username user123 password cisco
voice register pool 124
id mac 0041.D2B2.C291
type 7841
number 1 dn 124
username user124 password cisco
voice register pool 125
id mac 0041.D2B2.C2CA
type 7841
number 1 dn 125
username user125 password cisco
voice register pool 126
id mac 0041.D2B3.B6CD
type 7841
number 1 dn 126
username user126 password cisco
voice register pool 127
id mac 0041.D2B3.B75B
type 7841
number 1 dn 127
username user127 password cisco
voice register pool 128
id mac 0041.D2B3.B6BC
type 7841
number 1 dn 128
username user128 password cisco
voice register pool 129
id mac 0041.D2B3.B6C9
type 7841
number 1 dn 129
username user129 password cisco
voice register pool 130
id mac 0041.D2B3.B6A0
type 7841
number 1 dn 130
username user130 password cisco
voice register pool 131
id mac 0041.D2B3.B6D0
type 7841
number 1 dn 131
username user131 password cisco
voice register pool 132
id mac 0041.D2B3.B6BF
type 7841
number 1 dn 132
username user132 password cisco
voice register pool 133
id mac 0041.D2B3.B7DC
type 7841
number 1 dn 133
username user133 password cisco
voice register pool 134
id mac 0041.D2B3.B6A1
type 7841
number 1 dn 134
username user134 password cisco
voice register pool 135
id mac 0041.D2B3.B7C1
type 7841
number 1 dn 135
username user135 password cisco
voice register pool 136
id mac 0041.D2B2.C3A0
type 7841
number 1 dn 136
username user136 password cisco
voice register pool 137
id mac 0041.D2B2.C933
type 7841
number 1 dn 137
username user137 password cisco
voice register pool 138
id mac 0041.D2B2.C8EF
type 7841
number 1 dn 138
username user138 password cisco
voice register pool 139
id mac 0041.D2B2.C8D6
type 7841
number 1 dn 139
username user139 password cisco
voice register pool 140
id mac 0041.D2B2.C90C
type 7841
number 1 dn 140
username user140 password cisco
voice register pool 141
id mac 0041.D2B2.C51F
type 7841
number 1 dn 141
username user141 password cisco
voice register pool 142
id mac 0041.D2B2.C8AA
type 7841
number 1 dn 142
username user142 password cisco
voice register pool 143
id mac 0041.D2B2.C5C6
type 7841
number 1 dn 143
username user143 password cisco
voice register pool 144
id mac 0041.D2B2.C2B2
type 7841
number 1 dn 144
username user144 password cisco
voice register pool 145
id mac 0041.D2B2.C2E2
type 7841
number 1 dn 145
username user145 password cisco
voice register pool 146
id mac 0041.D2B2.C27E
type 7841
number 1 dn 146
username user146 password cisco
voice register pool 147
id mac 0041.D2B2.C226
type 7841
number 1 dn 147
username user147 password cisco
voice register pool 148
id mac 0041.D2B2.C28D
type 7841
number 1 dn 148
username user148 password cisco
voice register pool 149
id mac 0041.D2B2.C1CA
type 7841
number 1 dn 149
username user149 password cisco
voice register pool 150
id mac 0041.D2B2.C2FD
type 7841
number 1 dn 150
username user150 password cisco
voice register pool 151
id mac 0041.D2B2.C2C9
type 7841
number 1 dn 151
username user151 password cisco
voice register pool 152
id mac 0041.D2B2.C301
type 7841
number 1 dn 152
username user152 password cisco
voice register pool 153
id mac 0041.D2B2.C21A
type 7841
number 1 dn 153
username user153 password cisco
voice register pool 154
id mac 0041.D2B2.C27D
type 7841
number 1 dn 154
username user154 password cisco
voice register pool 155
id mac 0041.D2B2.C23F
type 7841
number 1 dn 155
username user155 password cisco
voice register pool 156
id mac 0041.D2B2.C296
type 7841
number 1 dn 156
username user156 password cisco
voice register pool 157
id mac 0041.D2B2.C2CB
type 7841
number 1 dn 157
username user157 password cisco
voice register pool 158
id mac 0041.D2B2.C244
type 7841
number 1 dn 158
username user158 password cisco
voice register pool 159
id mac 0041.D2B2.C339
type 7841
number 1 dn 159
username user159 password cisco
voice register pool 160
id mac 0041.D2B2.CB79
type 7841
number 1 dn 160
username user160 password cisco
voice register pool 161
id mac 0041.D2B2.C25E
type 7841
number 1 dn 161
username user161 password cisco
voice register pool 162
id mac 0041.D2B2.C268
type 7841
number 1 dn 162
username user162 password cisco
voice register pool 163
id mac 0041.D2B2.C657
type 7841
number 1 dn 163
username user163 password cisco
voice register pool 164
id mac 0041.D2B2.C1F4
type 7841
number 1 dn 164
username user164 password cisco
voice register pool 165
id mac 0041.D2B2.C307
type 7841
number 1 dn 165
username user165 password cisco
voice register pool 166
id mac 0041.D2B2.C206
type 7841
number 1 dn 166
username user166 password cisco
voice register pool 167
id mac 0041.D2B2.C279
type 7841
number 1 dn 167
username user167 password cisco
voice register pool 168
id mac 0041.D2B2.C3A5
type 7841
number 1 dn 168
username user168 password cisco
voice register pool 169
id mac 0041.D2B2.C336
type 7841
number 1 dn 169
username user169 password cisco
voice register pool 170
id mac 0041.D2B2.C28B
type 7841
number 1 dn 170
username user170 password cisco
voice register pool 171
id mac 0041.D2B2.C28C
type 7841
number 1 dn 171
username user171 password cisco
voice register pool 172
id mac 0041.D2B2.C631
type 7841
number 1 dn 172
username user172 password cisco
voice register pool 173
id mac 0041.D2B2.C8DF
type 7841
number 1 dn 173
username user173 password cisco
voice register pool 174
id mac 0041.D2B2.C396
type 7841
number 1 dn 174
username user174 password cisco
voice register pool 175
id mac 0041.D2B2.C2F0
type 7841
number 1 dn 175
username user175 password cisco
license udi pid C3900-SPE100/K9 sn FOC2035397R
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$i2sA$h1Be0KOH7l0j7Ce9fxTPT.
redundancy
interface Loopback1
ip address 100.30.0.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 100.30.60.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 100.30.70.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
nls resp-timeout 1
cpd cr-id 1
access-list 23 permit 10.10.10.0 0.0.0.127
access-list 23 permit 100.30.70.0 0.0.0.255
access-list 23 permit 100.30.60.0 0.0.0.255
control-plane
voice-port 0/1/0
connection plar 1001
caller-id enable
voice-port 0/1/1
connection plar 1002
caller-id enable
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
port 0/1/0
dial-peer voice 2 pots
port 0/1/1
prefix 0
gatekeeper
shutdown
banner exec
05-16-2022 10:15 PM
Although the below answer is not relevant to the above scenario because it is actually for failover conditions
but if you have only and only two voice VLANs within the same CME then you can apply:
ip source-address 10.100.1.1 port 2000 secondary 10.100.2.1
Again mentioning that it is actually for failover conditions that if one router fails then this secondary router will act as CME but you can apply this on 1 CME having two sub-interfaces for different voice VLANs
Still, desperately waiting for the useful answer
