Hi All,
We have a call manager 6.X cluster with remote sites. One of the remote locations is experiencing the low bandwidth error message. This message occurs sometimes throughout the peak times when no one is using the IP Phones. The WAN link is usually experiencing high latency of 300ms but the bandwidth is not being maxed out. The bandwidth is 10MB. The voice gateway is MGCP (2821) with T1 CAS PSTN.
All calls are made internally within the remote site and externally over the PSTN. No calls are made to other remote sites.
Remote site IP Phones
DP_M01, which has a location with audio bandwidth of 2MB and region of calls to other regions to use G729 and same region to use G711.
Remote site gateway
Assigned to DP_DC1, has a location with unlimited bandwidth and a region similar to above.
Can someone advise if there is any troubleshooting steps for this issue as I am out of options to try.
