"speed dial service" in Israel doesn't work
Does anyone know about how to use "speed dial service" in Israel?
Speed dial serivce is like an abbrevation number which has *XXXX(star and 4 digits).
It is used by companies to make it easy for customer to contact them.
I would like to use Speed dial service, but it doesn't work.
I have the following configuration.
<IP Phone>----<CUCM>-(H323)--<ISR>---(ISDN E1)--<Telco>
When a call was made , I got output of "debug isdn q931" as below.
"*2722" is the speed dial number of Avis(Car Rental office)
007043: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num xxxxxxxx
007044: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: Sending SETUP  callref = 0x0481 callID = 0x8402 switch = primary-net5 interface = User
007045: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8  callref = 0x0481
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x4181, 'xxxxxxxx'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xC1, '*2722'
007046: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8481
007047: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8481
        Cause i = 0x8083 - No route to destination
        Progress Ind i = 0x8088 - In-band info or appropriate now available
007048: Dec 15 03:31:21 CST: ISDN Se0/0/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8402
007049: Dec 15 03:31:28 CST: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x0481
007050: Dec 15 03:31:28 CST: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8481
        Cause i = 0x80E008 - Mandatory information element missing
Is there something wrong?  Should additional configuration be needed to work?
I wonder it is needed to trasnform *XXXX into actual number before sending.
Manish Gogna
2722 needs to be transformed to a number which your Service provider can accept and route, normally it is the complete number. Please transform it to the actual number on CUCM itself using a Translation pattern or on the Route List / Route group settings using Prefix settings. For an h323 gateway you can use translation rules on the gateway to convert it to the actual destination number.
Manish
Manish Gogna
Manish
Thank you very much for your reply.
I found that I needed to replace the * with 1222 before sending to telco.
So, I have done that transformation on CUCM, it works.
