RAI Detected (PRI error message)
ramiz.shaikh1
We are getting below error message and PRI continuously flapping
May 31 15:15:24.063 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
May 31 15:15:24.831 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
May 31 15:15:27.315 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/0
May 31 15:15:29.831 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
May 31 15:15:29.835 IST: ISDN Se0/0/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
May 31 15:15:29.835 IST: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
May 31 15:15:30.063 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
May 31 15:15:30.831 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
May 31 15:15:33.315 IST: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/0
May 31 15:15:45.831 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (May 31 15:15:24.063 IST: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/0
May 31 15:15:45.831 IST: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to down (RAI detected)
Below is the configuration on GW.
card type e1 0 0
clock timezone IST 5 30
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
I have raised it with telco and asked them to test with PRI meter, however Please let me know if configuration is fine from my end so that I can follow up better with them.
Rajan
Hi Ramiz,
As mentioned in the below discussion, try changing CRC to see if that helps.
https://supportforums.cisco.com/discussion/10218546/pri-error-message-rai-detected
If the issue persists, then it should be on the telco side.
Rajan
Pls rate all useful posts
Hi Ramiz,
RAI stands for Remote Alarm Indication.
If this was the working link, then, it is better to give physical loop from your/customer side [by joining TX and RX pairs ;1,2 with 4,5] and ask TELCO to check with BERT Meter.
regds,
aman
Jitender Bhandari
Hi Ramiz,
mostly happens because of isdn switch type mismatching between the Voice gateway and PSTN switch. See below detail
http://www.networking-forum.com/viewtopic.php?t=13790
(Rate if it helps)
JB
