10-14-2021 11:29 AM
Good Day All,
I presently have a Cisco 2901 Router with CME with a T1 connection (&100 DID numbers) from my provider.
Most calls work as intended but one in every few would forward the caller to the Providers VoiceMail box. The IP Telephony and Phones, Unified Communicationsperson would call in --> they can hear us but we can't hear them --> they would then be forwarded to the voicemail box from the provider after a few seconds. If they call back again, it would be fine. I have no voicemail services installed on my end and no call forwarding to the number being forwarded to in my configuration. The provider monitored the T1 line and said everything was fine on their end and that the problem may originate from my end. All DID numbers are affected by this issue at different times. We've had the T1 connection for 5 years. The first 3 years we had no issues (2 years of Covid Lockdown).
Any assistance would be greatly appreciated.
10-14-2021 11:58 AM
If you have debugs, what do they show?
If not, you'll need to get some debugs to try to figure out exactly what is going on.
10-14-2021 09:52 PM
Since you mentioned that you face one way audio, Have you checked the controllers. is there any errors ?
Could you please share the output of show controller t1
10-15-2021 05:53 AM
10-15-2021 06:19 AM
I can see errors on your PRI
Have you configure network clock commands ?
Could you please share the gateway Configuration ?
10-20-2021 12:50 PM
Was missing the network-clock-select command. No errors have been generated on the link for the past 8 hours and calls did not go to voicemail. Will continue to monitor and test to ensure it works completely.
10-20-2021 06:30 PM
These kind of issues are commonly seen if you don't configure Network Clock commands.
10-21-2021 10:00 AM - edited 10-21-2021 10:02 AM
Just had my first call going to voicemail. There are still no errors on the t1. Seems the issue still occurs.
Voice provider gave the following info:
Line Code: B8ZS
Framing: ESF
Signaling: NI2
I'm new to Cisco, so any help with commands and how to provide you with the necessary data, to assist us in determining the issue will be greatly appreciated.
10-21-2021 10:58 AM - edited 10-21-2021 10:59 AM
Configure those under Controller, But I am not sure about the signal NI2.
controller t1 0/2/0
framing ESF
linecode B8ZS
10-21-2021 11:10 AM
Yes already had these commands in.
10-21-2021 06:18 PM - edited 10-21-2021 06:38 PM
Then there Could some issues with ISP.
Could you please share the network commands you configured.
What router is this, ISR 4K or 29K ?
10-22-2021 06:26 AM
A Cisco 2901 router
xxxxxxxx#sh run
Building configuration...
Current configuration : 29611 bytes
! Last configuration change at 09:10:33 EST Wed Oct 20 2021 by xxxxxxxxxxx
! NVRAM config last updated at 10:57:47 EST Wed Oct 20 2021 by xxxxxxxxxxx
version 15.6
service timestamps debug datetime localtime
hostname xxxxxxxxxxx
boot-start-marker
boot-end-marker
card type t1 0 2
logging buffered 3000000
no logging console
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
ethernet lmi ce
clock timezone EST -4 0
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
ip dhcp excluded-address 10.1.1.1 10.1.1.100
ip dhcp pool VOICE
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip domain name xxxxxxxxxxxxxx.local
ip name-server 8.8.8.8
ip cef
no ipv6 cef
isdn switch-type primary-ni
trunk group FLOW
hunt-scheme sequential
crypto pki trustpoint TP-self-signed-2712614891
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2712614891
revocation-check none
rsakeypair TP-self-signed-2712614891
crypto pki certificate chain TP-self-signed-2712614891
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373132 36313438 3931301E 170D3133 30333231 31353333
32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37313236
31343839 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D1FC 4015F889 2A782C69 524C73BF 03EC4BCD BAB96A29 CDC30DFF 2E7E13B3
DC70F4C2 4134C0DE DA5CB629 0E03EC7A 3EC1A43A 355AD0FB 659E5617 0F7ABC66
AF26F5AC 23011054 A7D43298 3B9A23D1 FD5FB051 C6A61603 D3872566 6C706B85
B05140AF 71EBD0C3 4FA859A5 06AE7600 53D883D7 61D7AF06 75C29686 68889E9B
5D2F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14FC544D E9267662 180CCA8C 49012410 78DD79FE F4301D06
03551D0E 04160414 FC544DE9 26766218 0CCA8C49 01241078 DD79FEF4 300D0609
2A864886 F70D0101 05050003 81810075 B1584749 E993FB95 053CA22F 48AE9D28
374C585C 44780102 4FF7095B 92FC4085 C0BEF698 D15B07E4 300003C0 7F376AC9
B3DE5373 5E4C5661 CB0AB076 F990D98E A3917E57 979BF194 03584BF4 DD0B86E4
23582A90 2479EF13 77A3C461 BC44EE1E 32B7F1CD 71578845 3F043A3F 55E15F49
030DFAB7 646F6165 D43676AF 914DF9
quit
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 192.168.2.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
no update-callerid
voice class codec 1
codec preference 1 g722-64
codec preference 2 g711ulaw
codec preference 3 g711alaw
codec preference 4 ilbc
codec preference 5 g729r8
video codec h263+
video codec h264
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 150
max-pool 35
load 9951 cmterm.9-3-2-10
load 7821 sip78xx.11-0-1-11
authenticate register
authenticate realm 10.1.1.1
timezone 15
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0159152251673127
camera
video
voice register dn 1
number 8500
pickup-group 1
name xxxxxxxxxxxxxxxx
preference 1
no-reg
label xxxxxxxxxxxxxx
mwi
voice register dn 2
number 8501
call-forward b2bua all 8500
allow watch
pickup-call any-group
pickup-group 1
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 3
number 8505
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
mwi
voice register dn 4
number 8521
allow watch
pickup-group 1
no-reg
label xxxxxxxxxxxxxxxxx
mwi
voice register dn 5
number 8523
allow watch
pickup-group 1
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 6
number 8538
allow watch
pickup-group 1
no-reg
mwi
voice register dn 7
number 8524
allow watch
pickup-group 1
no-reg
mwi
voice register dn 8
number 8506
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
mwi
voice register dn 9
number 8539
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 10
number 8515
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxx
mwi
voice register dn 11
number 8509
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
mwi
voice register dn 12
number 8514
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxx
mwi
voice register dn 13
number 8534
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
mwi
voice register dn 14
number 8504
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
mwi
voice register dn 15
number 8541
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
label xxxxxxxxxx
mwi
voice register dn 16
number 8503
allow watch
pickup-group 1
no-reg
mwi
voice register dn 17
number 8510
allow watch
pickup-group 1
no-reg
mwi
voice register dn 18
number 8502
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
mwi
voice register dn 19
number 8519
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
label xxxxxxxxxxx
mwi
voice register dn 20
number 8517
allow watch
pickup-group 1
name xxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 21
number 8520
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxx
mwi
voice register dn 22
number 8537
allow watch
pickup-group 1
name xxxxxxxxxxxx
no-reg
mwi
voice register dn 23
number 8513
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
mwi
voice register dn 24
number 8511
allow watch
pickup-group 1
name xxxxxxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxxxxxxxx
mwi
voice register dn 25
number 8531
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 26
number 8535
allow watch
pickup-group 1
no-reg
label xxxxxxxxxxx
mwi
voice register dn 27
number 8536
allow watch
pickup-group 1
name xxxxxxxxxxx
no-reg
label xxxxxxxxxx
mwi
voice register dn 28
number 8518
allow watch
pickup-group 1
name xxxxxxxxxxx
no-reg
label xxxxxxxxxxx
mwi
voice register dn 29
number 8507
allow watch
pickup-group 1
name xxxxxxxxxxxx
no-reg
label xxxxxxxxxxxx
mwi
voice register dn 30
number 8512
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxx
mwi
voice register dn 31
number 8522
allow watch
pickup-group 1
name xxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 32
number 8595
allow watch
pickup-group 1
name xxxxxxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 33
number 8596
allow watch
pickup-group 1
name xxxxxxxxxx
no-reg
label xxxxxxxxxx
mwi
voice register dn 34
number 8540
pickup-group 1
label xxxxxx
voice register dn 35
number 8508
allow watch
pickup-group 1
name xxxxxxxxxx
no-reg
label xxxxxxxxxxxxx
mwi
voice register dn 36
number 8550
allow watch
pickup-group 1
name IP Phone
no-reg
label IP Phone
mwi
voice register dn 96
number 296
allow watch
name xxxxxxxxxxx
no-reg
label xxxxxxxx
mwi
voice register dn 101
number 8500
pickup-group 1
preference 2
no-reg
label xxxxxxxxx
mwi
voice register dn 102
number 8500
pickup-group 1
preference 3
no-reg
label xxxxxx
mwi
voice register dn 103
number 8500
pickup-group 1
preference 4
no-reg
label xxxxxxx
mwi
voice register dn 104
number 8500
pickup-group 1
preference 5
huntstop
no-reg
label xxxxxx
mwi
voice register template 1
feature-button 1 PickUp
feature-button 2 GpickUp
voice register pool 1
id mac 8478.ACE6.EAEF
session-transport tcp
type 9951 addon 1 CKEM
number 1 dn 1
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxxxx password xxxxxx
camera
video
blf-speed-dial 1 8538 label "xxxx"
blf-speed-dial 2 8515 label "xxxxxxx"
blf-speed-dial 3 8508 label "xxxx"
blf-speed-dial 4 8533 label "xxxxxxxx"
blf-speed-dial 5 8596 label "xxxxx"
blf-speed-dial 6 8597 label "xxxxx"
blf-speed-dial 7 8523 label "xxxxx"
blf-speed-dial 8 8518 label "xxxxx"
blf-speed-dial 9 8520 label "xxxxxx"
blf-speed-dial 10 8534 label "xxxxxxx"
blf-speed-dial 11 8524 label "xxxxxx"
blf-speed-dial 13 8509 label "xxxxx"
blf-speed-dial 14 8531 label "xxxxx"
blf-speed-dial 15 8540 label "xxxx"
blf-speed-dial 16 xxxxxxx label "xxxxxx"
blf-speed-dial 17 xxxxxx label "xxxxxxx"
voice register pool 2
id mac 8478.ACE6.3F9B
type 9951
number 1 dn 2
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxx password xxxx
camera
video
blf-speed-dial 1 296 label "Door Access"
voice register pool 3
id mac 8478.ACE6.40FE
type 9951
number 1 dn 3
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxx password xxxxx
camera
video
voice register pool 4
id mac 8478.ACE6.3F88
type 9951
number 1 dn 4
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 5
id mac 8478.ACE6.EBE3
type 9951
number 1 dn 5
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 6
id mac 8478.ACE6.3D83
type 9951
number 1 dn 6
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxx password xxxxxxxxx
camera
video
voice register pool 7
id mac 8478.ACE6.EEB2
type 9951
number 1 dn 7
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 8
id mac 8478.ACE6.E928
type 9951
number 1 dn 8
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 9
id mac 5897.1ECD.708F
type 9951
number 1 dn 9
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 10
id mac 8478.ACE6.3E18
type 9951
number 1 dn 10
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 11
id mac 8478.ACE6.ED92
type 9951
number 1 dn 11
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 12
id mac 8478.ACE6.E9DC
type 9951
number 1 dn 12
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 13
id mac 8478.ACE6.3F8E
type 9951
number 1 dn 13
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 14
id mac 5897.1ECD.AAB5
type 9951
number 1 dn 14
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xx password xxxx
camera
video
voice register pool 15
busy-trigger-per-button 2
id mac 38ED.1854.30AC
type 7821
number 1 dn 35
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 16
id mac 5897.1ECD.A9ED
type 9951
number 1 dn 16
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 17
id mac 5897.1ECD.6CDE
type 9951
number 1 dn 17
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
camera
video
voice register pool 18
id mac 3820.560C.3084
type 7821
number 1 dn 18
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 19
id mac 80E8.6F23.E054
type 7821
number 1 dn 19
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxxx password xxxxxx
voice register pool 20
id mac 38ED.1854.30D0
type 7821
number 1 dn 20
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 21
id mac 204C.9EB3.F049
type 7821
number 1 dn 21
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 22
id mac 3820.560C.4D7A
type 7821
number 1 dn 22
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 23
id mac BCF1.F2B4.1AB3
type 7821
number 1 dn 10
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
username xxxx password xxxxxxx
voice register pool 24
id mac 80E8.6F23.DF35
type 7821
number 1 dn 24
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 25
id mac 80E8.6F23.E055
type 7821
number 1 dn 25
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 26
id mac F0B2.E579.BE17
type 7821
number 1 dn 26
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 27
id mac BCF1.F2B4.1F96
type 7821
number 1 dn 27
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 28
id mac 80E8.6F23.E052
type 7821
number 1 dn 28
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 29
id mac 3820.560C.4D5F
type 7821
number 1 dn 29
template 1
presence call-list
dtmf-relay rtp-nte
voice-class codec 1
voice register pool 30
id mac F0B2.E579.71EC
type 7821
number 1 dn 6
voice-class codec 1
username x password xxxxxx
voice register pool 33
id mac 3820.560C.4FC0
type 7821
number 1 dn 33
voice-class codec 1
voice register pool 34
id mac 3820.560C.4F19
type 7821
number 1 dn 34
voice register pool 35
id mac 3820.560C.4FC3
type 7821
number 1 dn 11
voice translation-rule 1
rule 1 /^xxxxxx\(85..\)$/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
rule 2 /^0/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile DID_1
translate called 1
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile nondialable
translate called 1000
license udi pid CISCO2901/K9 sn FTX171283RS
license accept end user agreement
license boot module c2900 technology-package securityk9
hw-module ism 0
hw-module pvdm 0/1
redundancy
controller T1 0/2/0
cablelength short 110
pri-group timeslots 1-12,24
description T1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key xxxxxxxxxxxxx
pool SDM_POOL_1
acl 100
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
match identity group EZVPN_GROUP_1
client authentication list ciscocp_vpn_xauth_ml_1
isakmp authorization list ciscocp_vpn_group_ml_1
client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
description DATA-VLAN
encapsulation dot1Q 40
ip address 192.168.40.2 255.255.255.0
interface GigabitEthernet0/0.10
description VOICE-VLAN
encapsulation dot1Q 10
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet0/0.40
interface GigabitEthernet0/0.50
description GUEST-VLAN
encapsulation dot1Q 50
ip address 192.168.50.1 255.255.255.0
interface ISM0/0
description Unity Express
ip unnumbered GigabitEthernet0/0.10
ip virtual-reassembly in
service-module ip address 10.1.1.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.1.1.1
interface GigabitEthernet0/1
ip address 192.168.2.2 255.255.255.0
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Virtual-Template1 type tunnel
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
no ip address
ip local pool SDM_POOL_1 192.168.75.1 192.168.75.10
ip forward-protocol nd
ip http server
ip http access-class 50
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:
no ip ftp passive
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0.1 192.168.40.1
ip route 10.1.1.2 255.255.255.255 ISM0/0
ip route 10.1.1.10 255.255.255.255 ISM0/0
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/1
logging host 192.168.40.137
tftp-server flash:dkern9951.100609R2-9-3-2-10.sebn alias dkern9951.100609R2-9-3-2-10.sebn
tftp-server flash:kern9951.9-3-2-10.sebn alias kern9951.9-3-2-10.sebn
tftp-server flash:rootfs9951.9-3-2-10.sebn alias rootfs9951.9-3-2-10.sebn
tftp-server flash:sboot9951.031610R1-9-3-2-10.sebn alias sboot9951.031610R1-9-3-2-10.sebn
tftp-server flash:sip9951.9-3-2-10.loads alias sip9951.9-3-2-10.loads
tftp-server flash:skern9951.022809R2-9-3-2-10.sebn alias skern9951.022809R2-9-3-2-10.sebn
tftp-server flash:/apps37sccp.1-4-4-0.bin alias apps37sccp.1-4-4-0.bin
tftp-server flash:Desktops/640x480x24/List.xml
tftp-server flash:Desktops/640x480x24/mms25.png
tftp-server flash:Desktops/640x480x24/mmsphone.png
tftp-server flash:sip9951.9-3-2SR1-1.loads alias sip9951.9-3-2SR1-1.loads
tftp-server flash:rootfs78xx.11-0-1-1.sbn
tftp-server flash:rootfs2.78xx.11-0-1-1.sbn
tftp-server flash:kern78xx.11-0-1-1.sbn
tftp-server flash:kern2.78xx.11-0-1-1.sbn
tftp-server flash:sboot2.78xx.11-0-1-1.sbn
tftp-server flash:sboot78xx.11-0-1-1.sbn
tftp-server flash:sip78xx.11-0-1-1.loads
access-list 23 permit 192.168.40.0 0.0.0.255
access-list 50 remark CUCME WEB ACCESS
access-list 50 permit 10.1.1.2
access-list 50 permit 10.1.1.1
access-list 50 permit 192.168.40.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
control-plane
voice-port 0/0/0
trunk-group FLOW
connection plar opx 8500
description FXO
caller-id enable
voice-port 0/0/1
trunk-group FLOW
description FXO
caller-id enable
voice-port 0/0/2
trunk-group FLOW
description FXO
caller-id enable
voice-port 0/0/3
trunk-group FLOW
description FXO
caller-id enable
voice-port 0/2/0:23
voice-port 0/1/0
trunk-group FLOW
description FXO
caller-id enable
voice-port 0/1/1
shutdown
voice-port 0/1/2
shutdown
voice-port 0/1/3
voice-port 0/3/0
station-id name Fax
station-id number 8594
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.10
sccp ccm 10.1.1.1 identifier 2 version 4.0
sccp
sccp ccm group 1
associate ccm 2 priority 1
associate profile 1 register confprof1
associate profile 2 register VIDEOCONF
dspfarm profile 1 conference
codec g722-64
codec g711ulaw
associate application SCCP
shutdown
dial-peer voice 100 pots
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
destination-pattern 9990
forward-digits all
no sip-register
dial-peer voice 101 pots
destination-pattern 990
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 102 pots
destination-pattern 96[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 103 pots
destination-pattern 91[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 104 pots
destination-pattern 9011T
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 105 pots
destination-pattern 9[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 106 pots
destination-pattern 9999
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 107 pots
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 108 pots
destination-pattern 9555
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 109 pots
destination-pattern 555
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 110 pots
destination-pattern 00
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 1 voip
description Unity Express - Voicemail
destination-pattern 299
session protocol sipv2
session target ipv4:10.1.1.2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description Unity Express - AA
destination-pattern 298
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
description Unity Express - Prompt Management
destination-pattern 295
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 5 pots
destination-pattern 8594
port 0/3/0
dial-peer voice 150 pots
destination-pattern xxxxxxxxxxxx
forward-digits all
dial-peer voice 4 pots
description DID
translation-profile incoming DID_1
incoming called-number xxxxxxxxx..
direct-inward-dial
presence
presence call-list
max-subscription 200
sip-ua
mwi-server ipv4:10.1.1.2 expires 3600 port 5060 transport udp
presence enable
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm tag 1 confprof1
conference hardware
no auto-reg-ephone
max-ephones 35
max-dn 150
ip source-address 10.1.1.1 port 2000
max-redirect 5
service directed-pickup gpickup
system message xxxxxxxxxxxxxxxxx
url services http://10.1.1.2/voiceview/common/login.do
url authentication http://10.1.1.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7937 apps37sccp.1-4-4-0
time-zone 14
date-format dd-mm-yy
voicemail 299
max-conferences 8 gain -6
call-park system application
dn-webedit
transfer-system full-consult
secondary-dialtone 9
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys hold Join Newcall Resume Select
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Redial Endcall Cfwdall Pickup Gpickup Callback
softkeys alerting Acct Callback Endcall
softkeys connected Hold Endcall Trnsfer Confrn Acct Park
keep-conference endcall
codec g722-64
ephone-dn 1 dual-line
number 8597
pickup-group 1
label Conference Room
description 8597
mwi sip
ephone-dn 2 octo-line
number A001
conference ad-hoc
preference 3
ephone-dn 3 octo-line
number A002
conference ad-hoc
preference 3
ephone-dn 4 octo-line
number A003
conference ad-hoc
preference 3
ephone-dn 5 octo-line
number A004
conference ad-hoc
preference 3
ephone-dn 6 octo-line
number A005
conference ad-hoc
preference 3
ephone-dn 10 dual-line
number 8590
label x8590
description xxxxxxxxx
name xxxxxxxxxxxxx
mwi sip
ephone-dn 11
number 260
ephone-dn 35
number 8570
label xxxxxxxxxxxxx
name xxxxxxxx
mwi sip
ephone-dn 36
number 8550
name xxxxxxxxxxxxxx
ephone-dn 101
number 800... no-reg both
mwi on
ephone-dn 102
number 801... no-reg both
mwi off
ephone 1
device-security-mode none
mac-address 0004.F2F5.3DF7
type 7937
button 1:1
ephone 2
mac-address 0022.555F.462F
type 7970
button 1:10
ephone 3
mac-address 6057.18AB.973F
type CIPC
button 1:10
ephone 11
ephone 30
ephone 31
ephone 34
ephone 35
mac-address D22B.3BF5.BA8B
type CIPC
button 1:35
ephone 36
mac-address 2892.4A24.2999
type CIPC
button 1:1
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
logging synchronous
transport input telnet ssh
line vty 5 15
access-class 23 in
scheduler allocate 20000 1000
ntp master
ntp server 64.6.144.6
end
11-03-2021 11:22 AM
Any other ideas?
11-03-2021 06:01 PM
Are you still seeing errors on your controller ? I can see required network clock commands configured. If you see still error you need to talk to ISP.
11-04-2021 02:14 PM
