05-09-2019 01:04 PM
I have a lot of incomplete random calls being generated from the gateway. IOS upgrade fixes the issue but trying to figure out what could be the cause of these calls. These logs show only on dialpeer debug and call active voice, nothing in the isdn q931 debug.
SIP call-legs: 7
1F0A : 7133597 1862325056ms.1 (*17:50:17.790 EST Sun Dec 23 2018) +-1 pid:2 Answer 1 connecting
dur 00:00:00 tx:0/0 rx:0/0 dscp:0 media:0 audio tos:0x0 video tos:0x0
IP 192.168.1.83:25282 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
8B1 : 7183482 1911819956ms.1 (*07:35:12.690 EST Mon Dec 24 2018) +-1 pid:2 Answer 1 connecting
287D : 7695897 -1322798760ms.1 (*14:07:41.270 EST Sat Jan 5 2019) +-1 pid:2 Answer 1000 connecting
30DC : 14056001 804496168ms.1 (*15:08:10.792 EST Thu May 9 2019) +-1 pid:2 Answer 1001 connecting
30E1 : 14056002 804498908ms.1 (*15:08:13.532 EST Thu May 9 2019) +-1 pid:2 Answer 1001 connecting
30E6 : 14056003 804503028ms.1 (*15:08:17.652 EST Thu May 9 2019) +-1 pid:2 Answer 1001 connecting
30EB : 14056004 804506638ms.1 (*15:08:21.262 EST Thu May 9 2019) +-1 pid:2 Answer 1001 connecting
05-09-2019 06:30 PM
i caN SEE the 192.168.1.83 ip address what is this?
also, is that gateway connected to like cucm using SIP? or is it a cme router?
can you debug dial peer and or debug ccsip messages so you can establish the called and calling number.
cheers
05-09-2019 08:32 PM
1) I don't recognize 192.168.1.183 IP, none of my sites are on this subnet.
2) It is an H323 gateway.
3) These are all random calls, attached is 'debug ccsip message' output attached.
Usually it fixes itself after IOS upgrade, but for this router I just performed the upgrade and it is still happening.
05-09-2019 09:11 PM
I noticed all these SIP calls off of my gateway. I have removed sip-ua settings and rebooted the router, still no luck.
show sip-u calls br
Total SIP call legs:20, User Agent Client:0, User Agent Server:20
SIP UAC CALL INFO
Number of SIP User Agent Client(UAC) calls: 0
SIP UAS CALL INFO
No. CallId Calling# Called# RmtSignalIP RmtMediaIP
dstCallId SIPState SIPSubState
1 6581 242424 060001148178599102.165.49.170 192.168.1.83
-1 STATE_DISCONNECSUBSTATE_NONE
2 6585 600000001 90114415194707162.210.245.144 192.168.1.83
3 6590 202480 #65401148243625102.165.32.138 192.168.1.83
4 6592 1001 25200048833566062.210.101.111 192.168.1.83
5 6582 99890 637001148597213102.165.35.96 192.168.1.83
6 6580 500088 *61900011482215102.165.32.138 192.168.1.83
7 6579 12121212 061000011481785102.165.49.170 192.168.1.83
8 6596 1001 25300048833566062.210.101.111 192.168.1.83
9 6588 73001 **5970114891425102.165.49.170 192.168.1.83
10 6594 20910 632011485661010102.165.35.96 192.168.1.83
11 6595 46770 805+01148221530102.165.38.193 192.168.1.83
12 6587 66686 *86301148185419102.165.32.138 192.168.1.83
13 6584 9681141 **6010011481630102.165.49.170 192.168.1.83
14 6593 6003 01144151947075862.210.245.144 192.168.1.83
15 6578 46770 804+01148221530102.165.38.193 192.168.1.83
16 6577 1001 25000048833566062.210.101.111 192.168.1.83
17 6583 200 500740981016178102.165.36.171 192.168.1.83
18 6591 880070 619*01148122518102.165.38.193 192.168.1.83
19 6586 1001 25100048833566062.210.101.111 192.168.1.83
20 6589 10001 882011489142580102.165.38.64 192.168.1.83
Number of SIP User Agent Server(UAS) calls: 20
