ā09-06-2012 10:49 AM - edited ā03-16-2019 01:04 PM
I am using CME as SRST with Call Manger 8.6 with H323 gateway protocol and everything is working fine. My problem is that when the phone is on the SRST mode, the system message changes to my customized message. When the WAN connection is back, I can call other extension over the WAN but the system message doesn't change. How can I change the system message when the phone has connection to Call Manager without reseting the phone? Anybody has any idea? Appreciate the help.
Thanks!
ā09-06-2012 11:19 AM
So when it goes back to CUCM it keeps the SRST message on the display?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā09-06-2012 11:28 AM
Yes, the message doesn't change.
ā09-06-2012 12:00 PM
Sounds like a bug, perhaps firmware bug on the phones.
What phone models are you using and what firmware?
Chris
ā09-06-2012 12:29 PM
I am using 7942 with 9-2-1S
