Reason/Cause codes in SDL
brown3wab
Hi, I'm trying to determine a reason for call disconnects we are experiencing.  In SDL logs, examples below, I'm seeing the following Reason/Cause codes, though I'm unable to find a reference to determine what they mean. We are using Call Manager 10.5 and the phone in question is a 7962 using SCCP.  Thank you for any direction you may be able to provide.
                Line 10497: 05595791.000 |08:17:04.326 |SdlSig-O |CtiCallStateNotify                     |NA RemoteSignal                |UnknownProcessName(2,200,25,1)   |StationCdpc(5,100,64,3427)       |2,200,13,22.1159^10.X.X.X^SEP002497AB3A79 |[R:N-H:0,N:14,L:0,V:0,Z:0,D:0]  LH=2|8939 GCH=3|811193 CH=3|57510151 State=1(CtiIdleState) Reason=1 Cause=16 CGPN=[ DN=303856XXXX uDN=303856XXXX NumPI=T Part= VmBox= NumType=2 Name= UniName= NamePI=T Locale=1 PU=2 Device=S0/SU0/DS1-1@U1 GlblCgpn=69624] CDPN=[ DN=69614 uDN=69614 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name=Operator Agent UniName=Operator Agent NamePI=T Locale=1 PU=2 Device=] LRP=[ DN=69624 uDN=69624 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name= UniName=To Operator NamePI=T Locale=1] OCDPN=[ DN=69614 uDN=69614 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name=Operator Agent UniName=Operator Agent NamePI=T Locale=1] AuxData=F FarEndCMId=3 EndpointType=2 RIU=F Privacy=F Feat=1 SecStatus=1 SelectStatus=0 Feature=137 HuntCallClear=0 IsConsCallDueT...
                Line 16922: 05541584.000 |08:14:16.221 |SdlSig-O |CtiCallStateNotify                     |NA RemoteSignal                |UnknownProcessName(2,200,25,1)   |StationCdpc(5,100,64,3316)       |2,200,13,22.1143^10.X.X.X^SEP002497AB3A79 |[R:N-H:0,N:14,L:0,V:0,Z:0,D:0]  LH=2|8939 GCH=3|811091 CH=3|57509708 State=1(CtiIdleState) Reason=1 Cause=16 CGPN=[ DN=951464XXXX uDN=951464XXXX NumPI=T Part= VmBox= NumType=2 Name= UniName= NamePI=T Locale=1 PU=2 Device=S0/SU0/DS1-1@U1 GlblCgpn=69630] CDPN=[ DN=69614 uDN=69614 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name=Operator Agent UniName=Operator Agent NamePI=T Locale=1 PU=2 Device=] LRP=[ DN=69630 uDN=69630 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name= UniName=To Operator NamePI=T Locale=1] OCDPN=[ DN=69614 uDN=69614 NumPI=T Part=AllCall_PT VmBox= NumType=0 Name=Operator Agent UniName=Operator Agent NamePI=T Locale=1] AuxData=F FarEndCMId=3 EndpointType=2 RIU=F Privacy=F Feat=1 SecStatus=1 SelectStatus=0 Feature=137 HuntCallClear=0 IsConsCallDueT...
Manish Gogna
Ideally this needs to be investigated by looking at the exact call flow and protocols involved. By checking the signaling we can see which party/side is initiating the disconnect, the cause code 16 is a generic one.
Manish
Jitender Bhandari
Below is the list of "Call Termination Cause Codes"
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/10_0_1/cdrdef/CUCM_BK_CBB143DE_00_cucm-cdr-administration-guide-100/CUCM_BK_CBB143DE_00_cucm-cdr-administration-guide-100_chapter_0101.html
16
Normal call clearing
Also see below series which would help.
https://supportforums.cisco.com/document/13019091/how-i-read-callmanager-service-traces-video-series
(Rate if it helps)
JB
Thank you, KB.  Based on the document you shared would this be Reason= Call forward busy Cause= Normal Call Clearing?
B
