Recording ThirdParty SIP Phone
mrzh009811
hi,
i have a third party sip phone (YeaLink) which is not support BIB(built-in bridge) for recording with MediaSense,
how config this 3rd party sip phone to record its voice with cucm ?
scr.sybex1
Dear
Did you found anything?
Hi there
Use CUBE recording for recording the other media (3rd party SIP devices, analogue phones connected with the voice gateway, CTI-ports, etc.) if your Cisco router supports media forking.
Use SPAN in all other cases, for example – when you don’t have a forking CUBE or you need to record internal calls of endpoints without BIB (the voice traffic is not going through the Cisco gateway)
https://community.cisco.com/t5/ip-telephony-and-phones/mediasense-and-sip-3rd-party-phone-recording-problem/td-p/3372800
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
