Register IPPhone with advanced feature VPN
I need some clue to configure the VPN feature on CUCM 8.0.2 with ASA 8.0.5
I got the the guidelines but i need the more info about the config on the ASA.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_2/secugd/secvpfet.html
How can I get this ?
Uploading VPN Concentrator Certificates
Cisco recommends that you generate a certificate on the ASA when you set it up to support the VPN
feature. Download the generated certificate to your PC or workstation and then upload it to Cisco Unified
Communications Manager using the procedure in this section. Cisco Unified Communications Manager
saves the certificate in the Phone-VPN-trust list.
Please Help
thanks from now!
Alex
8 Replies 8
jomcgaug
Level 4
Level 4
Hi Alex,
Here's some useful links.
https://supportforums.cisco.com/docs/DOC-9124
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808efbd2.shtml
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008071c428.shtml
Here's a step by step guide.  Let me know if this helps.
Download the Cisco_Manufacturing_CA and CAPF certs from CUCM.  This is only needed for device level certificate authentication.  If the cluster is in Mixed Mode, you’ll need to add the CallManager cert as well.
Download certificates from CUCM
1.       Go to the Cisco UCM Operating System Administration web page.
2.       Choose Security > Certificate Management. (this location may change based on the UCM version)
3.       Find the certificates CallManager, Cisco_Manufacturing_CA, and CAPF. Download the .pem file and save as .txt file
Import certificates into the ASA
1.       Create the CallManager trustpoint.
hostname(config)# crypto ca trustpoint CallManager
hostname(config-ca-trustpoint)# enrollment terminal
hostname(config)# crypto ca authenticate CallManager
When prompted for base 64 encoded CA Certificate, copy-paste the text in the downloaded CallManager.pem file along with the BEGIN and END lines.
2.       Create the Cisco_Manufacturing_CA trustpoint.
hostname(config)# crypto ca trustpoint Cisco_Manufacturing_CA
hostname(config)# crypto ca authenticate Cisco_Manufacturing_CA
When prompted for base 64 encoded CA Certificate, copy-paste the text in the downloaded Cisco_Manufacturing_CA.pem file along with the BEGIN and END lines.
3.       Create the CAPF trustpoint.
hostname(config)# crypto ca trustpoint CAPF
hostname(config)# crypto ca authenticate CAPF
When prompted for base 64 encoded CA Certificate, copy-paste the text in the downloaded CAPF.pem file along with the BEGIN and END lines.
Create the VPN trustpoint and generate self-signed certificate
1.       Create ssl keypair.
hostname(config)# crypto key generate rsa label sslvpnkeypair modulus 1024
2.       Create the VPN trustpoint.
hostname(config)# crypto ca trustpoint ASA_VPN
hostname(config-ca-trustpoint)# enrollment self
hostname(config-ca-trustpoint)# keypair sslvpnkeypair
!---For the CallManager certificate to work with host-id check enabled on the VPN profile in CUCM, the following should be added.
hostname(config-ca-trustpoint)# fqdn
hostname(config-ca-trustpoint)# subject-name CN=, CN=
hostname(config)# crypto ca enroll ASA_VPN
3.       Assign trustpoint to outside interface.
ssl trust-point ASA_VPN outside
Export the VPN certificate and upload to CUCM.
1.       Export the VPN certificate.
hostname(config)#crypto ca export ASA_VPN identity-certificate
2.       Upload certificate to CUCM.
Click Upload Certificate and select the Phone-VPN-Trust store.
Browse to the exported VPN certificate file and click Upload File.
That covers the cert part.  Here’s snippets from the VPN parts of the config.
enrollment terminal
crl configure
crypto ca trustpoint CiscoMfgCert
enrollment terminal
crl configure
crypto ca trustpoint UCM_CAPF_Cert
enrollment terminal
crl configure
enrollment self
crl configure
crypto ca certificate chain CallManager
certificate ca 459b7a30cc05688e
crypto ca certificate chain CiscoMfgCert
certificate ca 6a6967b3000000000003
crypto ca certificate chain UCM_CAPF_Cert
certificate ca 5b0656231631591d
crypto ca certificate chain ASA_VPN
certificate 2509c62b000000000021
webvpn
enable outside
svc image disk0:/anyconnect-win-2.5.1025-k9.pkg 1
svc enable
tunnel-group-list enable
group-policy SSLCLientPolicy internal
group-policy SSLCLientPolicy attributes
dns-server value 10.1.1.1
vpn-tunnel-protocol IPSec svc webvpn
default-domain value cisco.com
address-pools value SSLClientPool
webvpn
  svc dtls enable
  svc keep-installer installed
  svc keepalive 120
  svc rekey time 4
  svc rekey method new-tunnel
  svc dpd-interval client none
  svc dpd-interval gateway 300
  svc compression deflate
  svc ask none default webvpn
!---Username+password authentication example
username vpnuser password i5k2dTp7PNxLQwDy encrypted
username vpnuser attributes
vpn-group-policy SSLCLientPolicy
service-type remote-access
!---Device+password authentication example
username CP-7975G-SEP001AE2BC16CB password k1kLGQIoxyCO4ti9 encrypted
username CP-7975G-SEP001AE2BC16CB attributes
username cisco123 password ffIRPGpDSOJh9YLq encrypted privilege 15
tunnel-group SSLClientProfile type remote-access
tunnel-group SSLClientProfile general-attributes
address-pool SSLClientPool
default-group-policy SSLCLientPolicy
tunnel-group SSLClientProfile webvpn-attributes
group-alias SSLVPNClient enable
group-url https://172.16.1.1/SSLClientProfile enable
John
Hi John,
I have ip phones in remote sites
Cisco said you should register your ip phones localy before sending them to remote sites
But i'm trying to configure them remotly
I have an external tftp server, and can successfuly send the configuration file to the ip phone at remote sites, also i'm able to upgrade and downgrade the phone
The problem is that i can't send the needed certificate to the ip phone, so the phone can't connect.
Is there any way to send the certificate to the phone without connecting it to the call manager ??
Haitham
Hi Haitham,
Unfortunately the only way to get the VPN cert on the phone is to register the phone to the CallManager first.
The only time I've seen someone configure the phone for VPN while it was remote, was by first registering the phone via ASA Phone Proxy.  This particular cusotmer was migrating from Phone Proxy to the VPN client.  Because the phone was registered via Phone Proxy, they could enable VPN and this would push the cert to the phone.  Not sure if that's an option for you.
John
No,
the remote phones is new and will need to have a new fw upgrade also for its conf also for the certificate
I'm thinking for something
If I do NAT for the call manager ip address with public one
then have this ip as tftp server ip add on the remote phone
Could the phone download the certificate at this time or as i though also the certificate isn't given to the phone via tftp ??
Thanks & Best Regrads
Haitham
The phone needs to register to CallManager in order for it to get the VPN cert.  That's the key.  If you can do so using NAT, then it should work.
John
jomcgaug,
the step by step you listed is the exact opposite of what cisco recommends. Cisco recommends that you create a cert on the ASA and import that into CUCM.
How do i do what cisco recommends?
"Cisco recommends that you generate a certificate on the ASA when you set it up to support the VPN
saves the certificate in the Phone-VPN-trust list."
The step by step procedure covers that part.  Look for the "Create the VPN trustpoint and generate self-signed certificate" and "Export the VPN certificate and upload to CUCM" sections.
Is that what you are looking for?
John
Ok Thanks John!
I'll pick it up from that point in the step by step.
PB
