Bookmark
Subscribe
3350
Register sip phone without callmanager
To start, I'm running my own asterisk server and have setup multiple sip softphones and a POTS to IP adapter with sip.
I recently got a real IP phone to hook up to my phone system, and have set it up with the sip firmware thanks to the community. That post is HERE.
The problem that I have run into is not knowing how to get it to register with a sip username and password. I can't figure out where to go to input the name and password for the sip setup. Every other device I've setup on my phone server had a clear indication of where to put the UN/PW.
Thanks everyone!
For an example of how things look when I set them up before:
17 Replies 17
Take a packet capture and see if the IP Phone is trying to register at all and what the format of the messages looks like in the current state.
The console logs from the phone's webpage should also have this information.
Good idea Brian.
Here is the console log from my phone. It doesn't look like it's trying to register at all.
http://pastebin.com/h17G7giy
I've tried doing a packet capture of my network, but having a bit of difficulty installing tcpdump into my router. Just a syntax error in loading the code, but I should have it figured out tonight/tomorrow.
Thanks.
Ideally you want the Asterisk and the phones in the same IP subnet.
I tried before putting them in different subnet and I sounded like a robot.
