Registering IP Phones with CME
Moatazmcitp
Dear Friends
I just got my CCNA RS and decided to go for CCNA Voice, and brought a lab kit (2811 router, 1841 router, 2 3560 switches, 2 phones 7961g)
I use CBT Nuggets to study, and I use the following infrastructure:
The problem that I have for three days looking and searching my whole day without any solution is my phones are not registering and I do not see them getting IP address while in DHCP binding in my DHCP Server I see that the server giving ips for devices that match the mac address of my phones.
Another thing is that I think that the phones are not getting firmware files from the CME              ,
CME Flash shows the flowing
1   59482968  c2800nm-adventerprisek9-mz.124-24.T5.bin
  2   3153295  apps41.9-3-1ES26.sbn
  3   556679   cnu41.9-3-1ES26.sbn
  4   2686807  cvm41sip.9-3-1ES26.sbn
  5   561605   dsp41.9-3-1ES26.sbn
  6   1631776  jar41sip.9-3-1ES26.sbn
  7   648      SIP41.9-3-1SR4-1S.loads
  8   648      term41.default.loads
  9   648      term61.default.loads
 10   5771325  cmterm-7941_7961-sip.9-3-1SR4-1.cop.sgn
 11   2215949  cvm41sccp.9-3-1ES26.sbn
 12   1630052  jar41sccp.9-3-1ES26.sbn
 13   652      SCCP41.9-3-1SR4-1S.loads
 14   5298719  cmterm-7941_7961-sccp.9-3-1SR4-1.cop.sgn
 15   1926568  cnu41.2-7-5-50.sbn
 16   1941998  CVM41.2-0-1-45.sbn
 17   689772   Jar41.2-9-1-45.sbn
 18   591      TERM41.7-0-2-0S.loads
One of my phone is rested to factory default and stuck on upgrade screen, because it is looking for suitable files to load.
When I issue load command I get:
CME_Voice(config-telephony)#load 7961 SCCP41.9-3-1SR4-1S.loads
LOAD COMMAND ERROR:cnf-file location system is not supported for creating automatic tftp bindings. Please use file location flash | slot0 | tftp OR create tftp bindings manually
Updating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
CNF files update complete for phonetype(7961)
Command of “Show ephone”:
ephone-1[0] Mac:001B.D40B.A49F TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
Show run on ever device:
CME_Voice#show run
Building configuration...
Current configuration : 1366 bytes
version 12.4
hostname CME_Voice
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
archive
 log config
  hidekeys
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
 ip address 172.16.1.1 255.255.255.0
 ip helper-address 172.16.2.5
interface FastEthernet0/0.50
 encapsulation dot1Q 50
 ip address 172.16.2.1 255.255.255.0
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
telephony-service
 max-ephones 5
 max-dn 5
 max-conferences 8 gain -6
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
 number 1111
ephone  1
 device-security-mode none
 mac-address 001B.D40B.A49F
 button  1:1
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
scheduler allocate 20000 1000
end
DHCP_Router#show run
Current configuration : 1042 bytes
version 12.4
hostname DHCP_Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp excluded-address 172.16.2.1 172.16.2.10
ip dhcp pool voice
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 8.8.8.8
   option 150 ip 172.16.1.1
ip dhcp pool data
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
   dns-server 8.8.8.8
no ip domain lookup
 ip address 172.16.2.5 255.255.255.0
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
ip http server
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
SwitchB#show run
Current configuration : 4152 bytes
version 12.2
no service pad
hostname SwitchB
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
no ip domain-lookup
crypto pki trustpoint TP-self-signed-1166977408
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1166977408
 revocation-check none
 rsakeypair TP-self-signed-1166977408
crypto pki certificate chain TP-self-signed-1166977408
 certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313636 39373734 3038301E 170D3933 30333031 30303031
  30365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31363639
  37373430 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D202 98000B00 CF0D0218 07FC8755 D177C77A CF40EF87 D2A97AD2 6E38745C
  2F576E90 6B209439 6870FF25 0F97EA0A 790ED758 4E8398D8 A0A298F6 757C024C
  98B40CFF 06D87E9F 820AA991 42B266F7 5F707ADF B358F1E9 F4B2107D F7FAF725
  8B9596FB 0CE7D8B5 E2B20013 A10488CD EC07738F 0C18BCC0 89791F1C 8CAB26F6
  24D90203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603
  551D1104 0C300A82 08537769 74636842 2E301F06 03551D23 04183016 801430B0
  BEB6793B 76D031B7 B9E44AFA 49E1F6DF 2CFE301D 0603551D 0E041604 1430B0BE
  B6793B76 D031B7B9 E44AFA49 E1F6DF2C FE300D06 092A8648 86F70D01 01040500
  03818100 C09602F4 02F86AA8 DFF6E55D FF5EC7E3 6AAA6A00 2F63422A C8FF8154
  368D5449 0AD30EE3 FC0AA464 FE612EAE 53CA0985 282171D3 E982FF1C 8F56EBF2
  77782ABD BE63FAA9 968B0CFD 59ADD411 B147E1EC 816D56FF 1C271630 0125B202
  BDE3E9DD 93862426 82844D08 254F460A 424A99A0 15E00BAB E94C6E4B E043C213 44CD9C0B
  quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
 switchport access vlan 50
 switchport mode access
 switchport voice vlan 10
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
 switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
ip classless
ip http server
ip sla enable reaction-alerts
line con 0
 exec-timeout 0 0
 logging synchronous
line vty 0 4
 login
line vty 5 15
 login
end
SwitchA#show run
Current configuration : 1488 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SwitchA
no aaa new-model
ip subnet-zero
no ip domain-lookup
no file verify auto
interface Vlan1
 no ip address
 shutdown
ip classless
ip http server
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line vty 0 4
 login
line vty 5 15
 login
end
Please Help it has been three days since I am working and no solution and I am thinking of giving up on CCNA Voice and go ahead and study for CCNP, since I studied for the whole CCNA RS and no such problem happened to me.
Kind Regards
2 Accepted Solutions
Put in the command "ntp server" or sync NTP to a source outside the firewall which will give you good time.
Please rate useful posts.
I would delete the ITL file by going to Settings -> Network Config -> Security and Delete the ITLs (I dont know the exact path off the top of my head). Better yet, i would factory reset the phone.
17 Replies 17
George Thomas
Level 10
Level 10
Under telephony-service, make sure that you specify the source address as the IP of the CME. Also make sure that the uplinks to the two routers are trunked on the switch.
Thanks for the reply
when i set the source address under the telephony service it give me this message:
Updating CNF files
About the trunk for the two routers, as you can see in the diagram dhcp port is access port (data vlan only) and CME is trunk port (for both voice and data) and voice devices get ip using ip helper to the main dhcp.
Thanks again
I got the time working and added the source address under telephony service, but still the phone is not registering.
I added the files in the flash to the tftp server hoping it can work but it did not.
here is my new config after making these amendments:
CME_Voice#show run
Current configuration : 2195 bytes
! Last configuration change at 22:07:51 UTC Mon Jul 28 2014
version 12.4
hostname CME_Voice
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
archive
 log config
  hidekeys
 no ip address
 duplex auto
 speed auto
 ip address dhcp
 duplex auto
 speed auto
ip http server
tftp-server flash:apps41.9-3-1ES26.sbn
tftp-server flash:cnu41.9-3-1ES26.sbn
tftp-server flash:cvm41sip.9-3-1ES26.sbn
tftp-server flash:dsp41.9-3-1ES26.sbn
tftp-server flash:jar41sip.9-3-1ES26.sbn
tftp-server flash:SIP41.9-3-1SR4-1S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:cmterm-7941_7961-sip.9-3-1SR4-1.cop.sgn
tftp-server flash:cvm41sccp.9-3-1ES26.sbn
tftp-server flash:jar41sccp.9-3-1ES26.sbn
tftp-server flash:SCCP41.9-3-1SR4-1S.loads
tftp-server flash:cmterm-7941_7961-sccp.9-3-1SR4-1.cop.sgn
tftp-server flash:cnu41.2-7-5-50.sbn
tftp-server flash:CVM41.2-0-1-45.sbn
tftp-server flash:Jar41.2-9-1-45.sbn
tftp-server flash:TERM41.7-0-2-0S.loads
control-plane
telephony-service
 max-ephones 5
 max-dn 5
 ip source-address 172.16.1.1 port 2000
 load 7961 flash:
 create cnf-files version-stamp 7960 Jul 28 2014 21:49:21
ephone-dn  1
 number 1111
ephone  1
 button  1:1
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
ntp server asia.pool.ntp.org
ntp server ru.pool.ntp.org
end
Can you try to register a CIPC (Cisco IP Communicator), it doesn't needs firmware.
Can you give below command under telephony-service and then create cnf.
Please attach "debug tftp event" as well when you trying to register 7961 phone.
Suresh
Thanks Man
I got my CIPC Registered. but once i ssue (load 7961 SCCP41.9-3-1SR4-1S)
it shows me :
Updating CNF files
Please Help
Plz put below command under telephony-service and check.
cnf-file location flash:
Suresh
Thank you very much, it worked you helped me alot
1- delete your ephone 1
2-kindly go to telephony-service and put the below
telephony-service
no  load 7961 flash:
no create cnf-files
create cnf-files
exit
3-Create again your ephone 1
4-Test
5-Share please  "show telephony-server tftp".
please rate all useful information
1- configure ntp server
ntp server x.x.x.x  where x.x.x.x public ntp server
or
interface loopback 0
ip address x.x.x.x x.x.x.x
exit
ntp server x.x.x.x
ntp source loopback 0
or
ntp server x.x.x.x source loopback0
then
R1#clock set 20:00:00 july 29 2014
2-look do under telephony-service
telephony-service
time-zone x   where x indicates your timezone ,
no create cnf-files
create cnf-files
Thanks, but I did what you told me and still nothing new.
here are the status messages i see in my phone
Also I see now in my phone under "network Statistics"  "IPV4 DHCP TIMEOUT"
I do not know if the problem is that my phone is not getting ip or something related to CME in TFTP or another thing?
Please Help me
I would move the DHCP server to the CME just for testing to isolate it as a network or config issue.
Ok I move the DHCP to CME
CME_Voice#show run | s dhcp
ip dhcp pool voice
   dns-server 8.8.8.8
 ip address dhcp
and my phone got a valid IP, but still does not register.
status messages shows:
trust list update failed
tftp timeout:sep001bd40ba49f (last 12 charterers are my PHONE MAC)
