Registration errors for SIP connection to VOIP Carrier
tysonshroyer
I'll preface this by saying I'm somewhat new to SIP trunks and still learning about the various config options, communication process between endpoints, and deciphering the debug output.
We have a pair of Cisco 2951s set up as our CUBE and a pair of SIP trunks to a cloud based voice service provider, one on each 2951.  There are also two targets on the carrier's end that we can connect to, one primary and one secondary.  We implemented these SIP trunks a few months ago to replace one of our PRIs, and we're routing our outbound long distance calls through them.
While looking in to an issue I did a "debug ccsip messages" and noticed a lot of registration messages going to our SIP circuit provider containing the destination patterns for some of our dial peers to register the routes, and registration is failing frequently.  We are getting tons of "400 Bad Request" responses, some "503 Service Unavailable" and some "401 Unauthorized".  We're able to make outbound long distance calls without any problems (only a small handful of reports of issues for calls that went through those trunks) so it doesn't appear to be interrupting service, but I'm wondering why we would be seeing these registration rejections.  I plan to speak to our carrier but wanted to gather more info first and get some opinions from anyone that would be capable of providing more insight.
Here's a sample of the debug ccsip messages output:
Aug 25 10:43:29.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip1.<sipcarrier>.com:5060 SIP/2.0
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE321538
From: <sip:1[2-9].........@sip1.<sipcarrier>.com>;tag=64EF6BD4-262F
To: <sip:1[2-9].........@sip1.<sipcarrier>.com>
Date: Tue, 25 Aug 2015 15:43:29 GMT
Call-ID: 33ED0FBD-4A4D11E5-8312E59E-FCBB666C
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1440517409
CSeq: 239 REGISTER
Contact: <sip:1[2-9].........@173.XXX.XXX.XXX:5060>
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:29.379: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip2.<sipcarrier>.com:5060 SIP/2.0
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE33259A
From: <sip:1[2-9].........@sip2.<sipcarrier>.com>;tag=64EF6BD8-181C
To: <sip:1[2-9].........@sip2.<sipcarrier>.com>
Call-ID: 33ED0FBD-4A4D11E5-8313E59E-FCBB666C
Max-Forwards: 70
CSeq: 239 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:29.399: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Bad Request
To: <sip:1[2-9].........@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.74a5
CSeq: 239 REGISTER
Server: OpenSIPS (1.7.1-notls (x86_64/linux))
Content-Length: 0
Aug 25 10:43:29.403: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:1[2-9].........@sip2.<sipcarrier>.com>;tag=7d26458774eb4e3f99fc82202e4d5adc.f515
CSeq: 239 REGISTER
Server: OpenSIPS (1.7.0-notls (x86_64/linux))
Content-Length: 0
Aug 25 10:43:29.875: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 239 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:29.879: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 239 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:29.891: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 239 REGISTER
Content-Length: 0
Aug 25 10:43:29.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 239 REGISTER
Content-Length: 0
Aug 25 10:43:30.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE341C1D
From: <sip:<username>@sip2.<sipcarrier>.com>;tag=64EF6F84-B95
To: <sip:<username>@sip2.<sipcarrier>.com>
Date: Tue, 25 Aug 2015 15:43:30 GMT
Call-ID: 1BB17467-3B1011E5-8003E59E-FCBB666C
Max-Forwards: 70
Timestamp: 1440517410
CSeq: 21232 REGISTER
Contact: <sip:<username>@173.XXX.XXX.XXX:5060>
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.343: //1069775/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:<username>@sip2.<sipcarrier>.com>;tag=7d26458774eb4e3f99fc82202e4d5adc.d0ed
WWW-Authenticate: Digest realm="sip2.<sipcarrier>.com", nonce="<removed>"
Content-Length: 0
Aug 25 10:43:30.343: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE35435
Max-Forwards: 70
CSeq: 21233 REGISTER
Expires: 60
Authorization: Digest username="<username>",realm="sip2.<sipcarrier>.com",uri="sip:sip2.<sipcarrier>.com:5060",response="<removed>",nonce="<removed>",algorithm=md5
Content-Length: 0
Aug 25 10:43:30.367: //1069775/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
To: <sip:<username>@sip2.<sipcarrier>.com>;tag=7d26458774eb4e3f99fc82202e4d5adc.9c20
Contact: <sip:<username>-mr521jpujgjjf@206.XXX.XXX.XXX:5060;transport=udp>;expires=223
P-Registrar-Error: Too many registered contacts
Content-Length: 0
Aug 25 10:43:30.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Expires: 60
Content-Length: 0
Aug 25 10:43:30.391: //1069775/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Aug 25 10:43:30.615: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE362365
From: <sip:911@sip1.<sipcarrier>.com>;tag=64EF70AC-1E4B
To: <sip:911@sip1.<sipcarrier>.com>
Call-ID: 33EC7395-4A4D11E5-8310E59E-FCBB666C
Max-Forwards: 70
CSeq: 598 REGISTER
Contact: <sip:911@173.XXX.XXX.XXX:5060>
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.635: //1069776/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:911@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.7bb4
CSeq: 598 REGISTER
WWW-Authenticate: Digest realm="sip1.<sipcarrier>.com", nonce="<removed>"
Content-Length: 0
Aug 25 10:43:30.639: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE371DE1
Max-Forwards: 70
CSeq: 599 REGISTER
Expires: 60
Authorization: Digest username="<username>",realm="sip1.<sipcarrier>.com",uri="sip:sip1.<sipcarrier>.com:5060",response="<removed>",nonce="<removed>",algorithm=md5
Content-Length: 0
Aug 25 10:43:30.659: //1069776/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:911@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.c7ce
CSeq: 599 REGISTER
Contact: <sip:911-mr521jpujgjjf@69.XXX.XXX.XXX:5060;transport=udp>;expires=254
Content-Length: 0
Aug 25 10:43:30.659: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 599 REGISTER
Expires: 60
Content-Length: 0
Aug 25 10:43:30.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE38F0
From: <sip:9011*@sip1.<sipcarrier>.com>;tag=64EF70E0-1FCE
To: <sip:9011*@sip1.<sipcarrier>.com>
Call-ID: 33ED0FBD-4A4D11E5-8314E59E-FCBB666C
Max-Forwards: 70
CSeq: 598 REGISTER
Contact: <sip:9011*@173.XXX.XXX.XXX:5060>
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.679: //1069776/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 599 REGISTER
Content-Length: 0
Aug 25 10:43:30.687: //1069777/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:9011*@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.29fa
CSeq: 598 REGISTER
Content-Length: 0
Aug 25 10:43:30.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE39470
Max-Forwards: 70
CSeq: 599 REGISTER
Expires: 60
Content-Length: 0
Aug 25 10:43:30.719: //1069777/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:9011*@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.c237
CSeq: 599 REGISTER
Contact: <sip:9011*-mr521jpujgjjf@69.XXX.XXX.XXX:5060;transport=udp>;expires=254
Content-Length: 0
Aug 25 10:43:30.719: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 599 REGISTER
Expires: 60
Content-Length: 0
Aug 25 10:43:30.739: //1069777/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 599 REGISTER
Content-Length: 0
Aug 25 10:43:30.795: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE3A667
From: <sip:<username>@sip1.<sipcarrier>.com>;tag=64EF7160-CBE
To: <sip:<username>@sip1.<sipcarrier>.com>
Call-ID: 1B92F06D-3B1011E5-8002E59E-FCBB666C
Max-Forwards: 70
CSeq: 19772 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.819: //1069778/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:<username>@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.764c
Content-Length: 0
Aug 25 10:43:30.819: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 173.XXX.XXX.XXX:5060;branch=z9hG4bKFAE3BB0B
Max-Forwards: 70
CSeq: 19773 REGISTER
Expires: 60
Content-Length: 0
Aug 25 10:43:30.839: //1069778/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:<username>@sip1.<sipcarrier>.com>;tag=c761273971bd0661c4f21d408b317b00.5cac
Contact: <sip:<username>-mr521jpujgjjf@69.XXX.XXX.XXX:5060;transport=udp>;expires=280
Content-Length: 0
Aug 25 10:43:30.875: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 239 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.879: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 239 REGISTER
Expires:  60
Supported: path
Content-Length: 0
Aug 25 10:43:30.891: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 239 REGISTER
Content-Length: 0
Aug 25 10:43:30.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 239 REGISTER
Content-Length: 0
Vivek Batra
Can you please share the output of 'show run'? This will better tell us how your dial-plan is and what changes you need to have to stop additional REGISTER triggers.
Added
Jonathan Schulenberg
Does your SIP carrier actually require registration or merely digest authentication? You're configuration has both.
sip-ua
 credentials username <removed> password 7 <removed> realm <sipcarrier>
 authentication username <removed> password 7 <removed>
 retry invite 2
 retry register 5
 registrar 1 dns:sip1.<sipcarrier>.com expires 60 refresh-ratio 90
 registrar 2 dns:sip2.<sipcarrier>.com expires 60 refresh-ratio 90
In fact, it's worth verifying whether the provider even requires digest authentication. Does a call that works include a '407 Proxy Authentication Required' response to the first SIP INVITE followed by a second INVITE with the credentials in it? If not then digest authentication isn't happening either.
