registration rejected when subscriber server is active
CSCO11555492
Greeting
in my cluster i have 2 Cisco Call manager 7.0.2 one as publisher other as a subscriber installed in VMware enviroment i have notice that when i
activate subscriber all services IP phone goes to registration rejected and any change in IP phone configuration , gateways or any thing dose not take effect unless i shutdown subscriber server
Please advise
6 Replies 6
7.x is not supported in a  VMware environment
Maybe this is the problem
The PUB is in MCS and SUB is in vmware?
Please rate all useful posts
Chrysostomos
""Thinking is the hardest work there is , which is probably the reason why so few engage in it""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
I agree CUCM 7 .x is not supported in VMWare.You need to have 8.0(3) for VM .
Can u share the DBreplication from Cisco unified reporting tool?
regds,
aman
thank you so much for your response actually i just want to confirm this is issue with VMware not an issue with configuration because i am preparing for CCIE voice lab and enviroment which am talking about is my home lab,
i dont want to face this issue in the exam
by the way this behavior happen once i change hostname to IP Address in enterprise parameter
Hi Ahmed,
Did u do installation when DNS was there in setup ?
If yes, is primary and secondary DNS still configured in servers.You can use show network eth0 details command from CLI through Putty.
regds,
aman
No i didnt have any DNS server in the lab
Hope that u have configured Subscriber with IP address in System---Server and cisco unified CM and Cisco Unified CM Group.
Also,restart Sub.
regds,
aman
