Remote Access to User Mailbox not working
larryar28
I have a customer running CUC 1.2. There are two identical users where one can access the vm remotely with the * key and the other one cannot. When trying to access, the mailbox does not respond to the DTMF tone for the * or 0 in Caller input. I believe this is a default setting so I tried to delete and reinstall VM but still the same problem for this user. Any suggestion would be appreciated.
5 Replies 5
Rob Huffman
Hi Larry,
Compare the "Caller Input" settings for these two users. I'm guessing the working one
has Caller Input * set to Sign-In
User>Edit>Caller Input
Cheers!
Rob
I have checked all caller input settings. Both are set to "sign in" on the *. The same applies with the 0 out key. The CUC just will not recognize thee DTMF tones at all
Rob Huffman
Hi Larry,
OK .....have you checked to see what Greeting each user is using? There
can be a different behavior set for the Standard vs Alternate for example.
Cheers!
Rob
Both users are set to Standard greeting and all proramming is identical.
Rob Huffman
Hi Larry,
Well....I'm kind of stumped here??
I did check the Bug Toolkit to see if there were any Bugs related
to DTMF or Caller Input in CUC 1.2 and couldn't see anything specific that would
relate to this issue.
I'm sure you have done this, but I wanted to just check that you have tried this
from a "known" working phone? I remember trying to troubleshoot a similar issue
for days only to find that the user was trying to access the VM from home using
a crappy Duck phone that only used "Pulse" dialing. Just to be sure as well....these
users are dialing their personal number and then trying to * back to sign-in? There
is no remote access #.....?
Cheers!
Rob
