remote ip phone over VPN using CME 3.3
cempuerto
I like to ask for help configuring the 2811 router with CME 3.3 I am planning to have an ip phone on a remote site connected to this router over VPN. IP phones on the remote site have different subnet from the ip phone on the other site. Need help to configure the router to see the ip phones on the remote site.
i have a asa5505 on the remote location and asa5520 on the other site.
Cempuerto
Marwan ALshawi
from what i understood !!
ur topology looks like
CME---ASA---internet---ASA--remote ip phones
so based on this topology and ur requiremnts
u need to build normal site-to site vpn
and for example lets say u have the following IP addressing
192.168.1.0/24(voice)CME-.1--172.16.1.0/24--.2 ASA--internet--ASA--10.1.1.0/24
on the ASA connected to the CME u need to have a route to the inside like:
route inside 192.168.1.0 255.255.255.0 172.16.1.1
now on the same ASA the main site u need to have two important ACLs for vpn
one for interesting traffic and one for nat exmption or NAT0 going from CME/ASA to remote LAN
based on our example:
interesting traffic:
access-list 100 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list 100 permit ip 172.16.1.0 255.255.255.0 10.1.1.0 255.255.255.0
now nat exmption:
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list 101 permit ip 172.16.1.0 255.255.255.0 10.1.1.0 255.255.255.0
on the ASA u may have the following
nat (inside) 1 0 0
global (outside) 1 interface
nat exmption like:
NAT (inside) 0 access-list 101
also keep in minde for vpn u need to have sccp, TFTP, and somtimes http included in the interesting traffic
additionaly on both ASA u can use
sysopt permite ipsec command to allwe all traffic through VPN
or u can do packet filltering on the outsid einterface but u need to permit all required traffic for voice
also make sure u have skiny inspection enabled on the defualt inspection policy
on the remote site u need to apply the same idea
like
access-list 100 permit 10.1.1.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 permit 10.1.1.0 255.255.255.0 172.16.1.0 255.255.255.0
and same for nat exmption
also on the client VOICE phone they need the option 150 set with CME ip address configured as a source address on the telephoney service to let those phones register with the CME
have a look at the following link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
good luck
if helpful Rate
6 Replies 6
gogasca
Level 10
Level 10
IP Phones needs only IP connectivity, you may post this request under the VPN forum for a better response.
thanks..i have a question. Its a must to have subinterface for voice vlan.right?? what if my switch is a l3 switch and the voice vlan interface is on the switch using intervlan routing.do i need to disable the ip routing on the switch so that i can use trunk line going to the router??
i fu have intervaln routing u cloud use this way
les say ur voice vlan o nthe switch is vlan10 withc ip subnet 10.1.1.0/24
and data vlan is vlan 5 with ip network 192.168.1.1
u should have already ccreated SVI for each vlan
interface vlan 10
ip address 10.1.1.1 25.255.255.0
no shut
interface vlan 5
no shut
now try to make the port connected to the CME which is the gateway at the same time as layer three port called routed port cor example
lets say the LAN interface of the CME is
172.16.1.1/24
make the switch port connected to the CME like:
interface fa0/24
no switchport
ip address 172.16.1.2 255.255.255.0
no shut
now make default route point to the router CME lan address like:
ip route 0.0.0.0 0.0.0.0 172.16.1.1
on the CME make two static routes point to each vlan through the switch routed interface for example
on CME
ip route 10.1.1.0 0.0.0.255 172.16.1.2
and for data as well this will help the ASA to get the lan networks !
in the CME u should have command like
telephney serive
ip source-addr 172.16.1.1
while this is the LAN interface ip of the CME
on the switch u could configure DHCP for each vlan like:
ip dhcp excluded-address 10.1.1.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool voice_vlan10
network 10.1.1.0 /24
option 150 172.16.1.1
default-router 10.1.1.1
ip dhcp pool data_vlan5
network 192.168.1.0 /24
default-router 192.168.1.1
dont forget to enable this comand on each access port
spaning-tree portfast
to avoid problem with getting ip from DHCP
good luck
if helpful Rate
i have this set up..phoes are getting the tftp setting but no dial tone on the phones.
My CME ip address is 10.48.0.1 and itis attacted to port 23 on the switch.
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool phone
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
option 150 ip 10.48.0.1
no file verify auto
spanning-tree mode pvst
interface GigabitEthernet0/1
switchport access vlan 10
interface GigabitEthernet0/2
interface GigabitEthernet0/3
duplex full
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 20
speed 100
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport mode access
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
switchport access vlan 3
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
spanning-tree portfast
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
description Management VLAN
ip address 10.48.0.2 255.255.255.0
interface Vlan2
ip address 10.48.1.3 255.255.255.0
ip helper-address 10.48.0.100
ip helper-address 10.48.1.4
interface Vlan3
ip address 10.48.2.3 255.255.255.0
ip helper-address 10.48.0.101
ip helper-address 10.48.2.4
ip policy route-map admin
interface Vlan10
no ip address
interface Vlan20
no ip address
interface Vlan100
no ip address
interface Vlan400
description voice vLAN
ip address 10.10.10.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.48.0.1
ip http server
ip http secure-server
access-list 1 permit 10.48.1.0 0.0.0.255
access-list 2 permit 10.48.2.0 0.0.0.255
access-list 3 permit 10.48.0.0 0.0.0.255
route-map test permit 10
match ip address 1
set ip next-hop 10.48.0.1
route-map admin permit 20
match ip address 2 3
set ip next-hop 10.48.0.103
here's my router configuration:
no ip domain lookup
ip name-server 10.48.0.100
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 9
rule 1 /^166$/ /166/
rule 2 /^9\(.*\)/ /\1/
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
interface FastEthernet0/0
ip address X.X.X.X X.X.X.X
ip access-group 102 in
no ip redirects
no ip unreachables
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description UPRouter inside network$ETH-LAN$
ip address 10.48.0.1 255.255.255.0
ip access-group 160 in
ip nat inside
no ip mroute-cache
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X permanent
ip route 10.10.10.0 255.255.255.0 FastEthernet0/1
ip route 10.48.1.0 255.255.255.0 10.48.0.2
ip route 10.48.2.0 255.255.255.0 10.48.0.2
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip http path flash:
ip nat inside source list 2 interface FastEthernet0/0 overload
ip nat inside source static tcp 10.48.0.102 80 X.X.X.X 80 extendable
tftp-server enable
tftp-server flash:CP7905060000SCCP050124A.sbin
telephony-service
load 7905 CP7905060000SCCP050124A
max-ephones 36
max-dn 108
ip source-address 10.48.0.1 port 2000
calling-number initiator
system message UpV
time-zone 5
date-format dd-mm-yy
create cnf-files version-stamp 7960 Sep 06 2008 19:17:00
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name cisco secret 5 $1$hQ1G$8UPiyi.2PAU/5/3LIK5Lr1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
ephone-dn 1
number 201
label 201
description USER1
name USER1
corlist incoming user900-international
ephone-dn 2
number 202
label 202
description USER2
name USER2
ephone 1
username "user1" password 201
mac-address 001F.6C7E.D9E3
type 7905
button 1:1
ephone 2
username "user2" password 202
mac-address 001F.6C7E.DC18
type 7905
button 1:2
Marwan ALshawi
now nat exmption:
nat (inside) 1 0 0
nat exmption like:
like
good luck
if helpful Rate
