06-14-2013 02:36 AM - edited 03-16-2019 05:52 PM
I have one question. All the IP phones are registered to Central CUCM. Can I know how customer use cue(voice mail) in remote site SRST ?
IP phones ---------------- poe Switches ----------- SRST (cue) --------------------- CE router ================ Central CUCM
Thanks and regards
Leung Che Man
06-14-2013 04:27 AM
The CUE-based SRSV solution with UMG has been EoL in exchange for a Unity Connection-based solution. In most cases the hardware is not reusable since the CXN-based SRSV solution requires a SRE-910 blade in the router.
Technically you could configure CUE as if it were a standalone product (i.e. install guide, then build mailboxes/IVRs) and tie it to SRST/CME using dial-peers; however, there would be no replication of the greetings or messages back to Unity Connection after you leave SRST.
Please remember to rate helpful responses and identify helpful or correct answers.
06-14-2013 08:02 AM
I don't think they have CUC, just the remote site CUE and phones registered to a central CUCM. And they want to keep using CUE if the WAN goes down and go into SRST.
In such case, you would need to use CME-as-SRST to configure CUE in there, when the WAN fails and phones register locally.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
06-14-2013 03:29 PM
Thanks for your information.
I still have some question. Can I know how customer extension number (cucm) associate with the voice mail in cue ? Do I need to add dial pattern to route to cue ? How do I config the mwi on/off ?
Thanks and Regards
Leung CHe Man
