remotely enable IP phone web interface
ruttersean
Does anybody know if it is possible to remotely enable an IP phone web interface using for example an ephone- template or similar? ( I have looked at the ephone-template settings but it does not seem possible) any ideas?
6 Replies 6
paolo bevilacqua
Which phone model are you talking about? What issue are you trying to solve with having web interface on the phone (that BTW is enabled by default) ?
It's a 9951 on CME 9.0
On these phones the web interface is disabled by default.
I have a requirement to use a phone remote control tool in a remote office.
Sean
I don't know about the web interface on the 9951, but generally to remote control a phone you use TAPI, or XML, there are applications that do that.
So, to do this for SCCP phones enter the following under telephony-service
Service phone webAccess 0
I do not yet know if there is an equivalent for SIP phones under voice reg global
See if you can host the xml files on an  external tftp server, so you can edit them as desired.
sterdnotshaken
I have this same question... Running a SIP only CME 9.0 with 7942/62's and I want to be able to browse call stats and such via http much like you can do with SCCP phones... is this possible? Is there an equivelent voice registar global command to "service phone webAccess X"?
Thanks!
