IP Telephony and Phones
Labels
HI I have resently upgraded my cme to 8.8 & ios version isc2900-universalk9-mz.SPA.152-1.T2.binafter that on wards i am haveing problem .from the cme setup we will dial a  speed dial and the call is routed to ccm translation patten and  from the ccm ...
Hi, could someone clarify whether any DLU's are required when adding a VG224 and analogue phones? There seems to be some confusion with some people saying you do need DLUs when using SCCP?If anyone could confirm one way or the other it would be much ...
Hi All,I have a 39XX router as cme and cue (40 phone regiter it). That router is just connected to PSTN. So At this point I think that I dont have to make media resource configuration like blow. am I right ? or Which configuration should I make. I wi...
Hi Guys,I have a problem with some calls. When we try to call (PSTN to IPTel) the calls are direclty disconnect (not all some works, and some don't work)In the SDI traces I have the following:|3,100,152,1.894691^10.187.38.8^*17:26:37.065 |<MN::MGCPEn...
