remove 91 when forwarding to PSTN
Mario Lopez
I am having an issue that I can't quite solve.  I am new to Cisco UCM so please bare with me.  Essentially the issue is when a user forwards their line to their cell phone, or any external number, and that number is called from an external line, the caller ID shows up with a 91 prefix.  I found an article on how to remove the 91 when using MGCP but we are using H323.
Here is the main outbound dial-peer config
dial-peer voice 10 pots
 description Long Distance
 destination-pattern 91[2-9]..[2-9]......
 port 0/0/0:23
 forward-digits 11
Any help is appreciated.
Quick fix or bandage fix would be to apply below config on your router:
voice translation-rule 10
rule 1 /^91/ //
voice translation-profile CLID
 translate calling 10
translation-profile outgoing CLID
Normally Telco's would not allow you to display CLID for any range not part of your DID. Though it appears you have digit manipulation happening either in CUCM or using other methods on voice router like num-expansion etc. In the long run you may need to identify the digit manipulation and would suggest consolidate on the gateway using the voice translation rules.
Anyways make a quick test with the above config and let us know how you go.
-Terry
12 Replies 12
Terry Cheema
Can you provide the following from your gateway:
sh run | s translation
sh run | s dial-peer
-Terry
Please rate all helpful posts.
voice translation-rule 2
 rule 1 /^011\(.*\)/ /9011\1/
 rule 2 /\(..........\)/ /91\1/
voice translation-rule 210
 rule 1 /5440/ /2835/
voice translation-profile 210
 translate called 210
dial-peer voice 2 voip
 preference 1
 destination-pattern 714T
 session target ipv4:x.x.x.x
 voice-class codec 1
 dtmf-relay h245-alphanumeric
 no vad
 port 0/0/0:23
 forward-digits 11
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
 port 0/0/0:23
dial-peer voice 110 pots
 trunkgroup analog
 preference 1
 forward-digits 11
dial-peer voice 911 pots
 description Emergency
 destination-pattern 911
 port 0/0/0:23
 forward-digits all
dial-peer voice 912 pots
 trunkgroup Analog
 preference 1
 forward-digits all
dial-peer voice 411 pots
 description Information
 destination-pattern 9411
 port 0/0/0:23
 forward-digits 3
dial-peer voice 412 pots
 trunkgroup Analog
 preference 1
 forward-digits 3
dial-peer voice 611 pots
 description Repair
 destination-pattern 9611
 port 0/0/0:23
 forward-digits 3
dial-peer voice 612 pots
 trunkgroup Analog
 preference 1
 forward-digits 3
dial-peer voice 7 pots
 description Local
 destination-pattern 9[2-9]......
 port 0/0/0:23
 forward-digits 7
dial-peer voice 71 pots
 trunkgroup Analog
 description Local
 preference 1
 forward-digits 7
dial-peer voice 100 pots
 description Intl
 destination-pattern 011T
 port 0/0/0:23
 forward-digits all
dial-peer voice 101 pots
 trunkgroup Analog
 description Intl
 preference 1
 forward-digits all
dial-peer voice 9911 pots
 destination-pattern 9911
 port 0/0/0:23
 forward-digits 3
dial-peer voice 9912 pots
 trunkgroup Analog
 preference 1
 forward-digits 3
dial-peer voice 21 voip
 destination-pattern 23..
 voice-class codec 1
 no vad
Mario,
that configuration output does not contain a dialpeer with a translation rule applied to it
 port 0/0/0:23
 forward-digits 11
Please remember to rate useful posts, by clicking on the stars below.
That is correct.  This is the mess that I inherited.  Unfortunately nothing was documented so trying to put it all together as I audit these routers.
OK, so let me see if I understand this correctly, someone puts a call forward all on their desk phone to, for instance, point to their mobile. Then some external party will call the desk phone number and the mobile will ring with a 91..........  caller ID.   correct?
what about when that same deskphone calls that same mobile, without any call forward all, what is the caller ID then?
That is correct.  If a call comes from an external number, the caller ID contains 91.  If the call comes from an internal extension, the caller ID displays the person's DID (10 digit number).  If a person makes a call to the mobile phone directly, the proper caller ID is displayed (10 digit number).
I'll work on getting the screen shots and debug outputs.  Thanks everyone.
Mario,
Since you have the command forward-digits 11, it should automatically be stripping 91. Looks like you have some digit manipulation setup in CUCM.
Can you post screen shot of your H323 gateway below sections:
Call Routing Information - Inbound Calls
Call Routing Information - Outbound Calls
Can you also make a test call and post the following two debugs to start with:
debug isdn q931
debug voip ccapi inout
-Terry
Here are the files.
Calling Number 2225554444 (external phone number)
Called Number 3336665555 (number deskphone is forwarded to)
rule 1 /^91/ //
-Terry
Easiest way is to use forward-digits as you are, but that only removes the 9, not the 91. forward-digits 10 would send out just the 9..9...... (10 digits)
You could also use translation pattern as such:
   rule 1 /^91/ //
voice translation-profile StripDigits
    translate called 10
dial-peer voice X voip
    translation-profile StripDigits out
I'll give these a try tonight.  thanks
I tried these suggestions but 91 was still showing as the callerID.
