Showing results forĀ
Search instead forĀ
Did you mean:Ā
Removing old License Files on CUCM 8.6
Tracee Baddley
CUCM 8.6 Can (and if so, "Should") old license files be removed?  We have rehosted Publisher from MCS Server to Virtual Server.
If they should be removed, can they be removed from any place on the GUI interface, or will it have to be via a CLI command?
TB
Aaron Harrison
There is a CLI option:
file delete license
... I don't recall using it... old licenses are harmless, they just clutter up the interface a little.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
[+5] to Aaron
You can use the command from CLI file list license * to view all the license files.
You can them either one by one or issue command file delete license *
regds,
aman
