replace Cisco ip phone
A laban
i have one client who need to replace almost 1800 phones , he need just distribute the phone and the user just enter his extension. please your support .
8 Replies 8
balaji.bandi
You need to setup new phones for autoprovision with profiles as below example guide suggest you how to do.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/frame_source/500-series-7-5-7/ip_phone_admin/6_prov_basics.pdf
BB
thank you balaji.bandi ,
its not clear.
you can do as suggested other post, for the self provision.
but if that not what you looking, tell us more ?
BB
Jaime Valencia
https://www.unifiedfx.com/products/migrationfx-taps-af
java
if this helps, please rate
A laban
Thank you all , im going with self provision , but i face now one issue can we export and import the universal device profile because i have more than 300 device pool and i need create for each one universal device profile .
Thank you
Do You mean universal Device Template ? That cannot be exported.
Why Would you create separate Device Template for each Phone . You don't need to. You can simply create few based on the requirements.
If you mean Device Profiles then they can be exported.
**Please rate helpful posts
thank you ,  like what i told we have more than 300 device pool and i need to create for each device pool a universal Device Template  , because every device pool have 100 IP phones
