uc520 isdn trouble
Hi everyone..
Im having trouble with calls on a uc520.
Then for example i make an incomming call from the outside to a number the phone rings but ether disconnects when pickup or after a certain time.
Can anyone give me a hint what could be wrong ?
Debug isdb q931 output :
UC520#
000168: Jan  8 09:41:43.996: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8  callref = 0x01
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x89
        Exclusive, B1
    Called Party Number i = 0xA1, 'ISDN NUMBER'
        Plan:ISDN, Type:National
000169: Jan  8 09:41:43.996: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x01
    Sending Complete
        Standard = CCITT
    Channel ID i = 0x89
        Exclusive, B1
000170: Jan  8 09:41:44.032: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
000171: Jan  8 09:41:44.044: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
000172: Jan  8 09:41:44.056: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
000173: Jan  8 09:41:44.060: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
000174: Jan  8 09:41:44.064: ISDN BR0/2/1 Q931: TX -> ALERTING pd = 8  callref = 0x81
000175: Jan  8 09:41:49.244: ISDN BR0/2/0 Q931: TX -> CONNECT pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
000176: Jan  8 09:41:49.292: ISDN BR0/2/1 Q931: TX -> CONNECT pd = 8  callref = 0x81
    Channel ID i = 0x89
        Exclusive, B1
000177: Jan  8 09:41:49.356: ISDN BR0/2/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
000178: Jan  8 09:41:49.360: ISDN BR0/2/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
000179: Jan  8 09:41:49.360: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to 800 N/A
000180: Jan  8 09:41:49.360: %ISDN-6-CONNECT: Interface BRI0/2/0 is now connected to N/A N/A
000181: Jan  8 09:41:49.360: %ISDN-6-CONNECT: Interface BRI0/2/1:1 is now connected to 800 N/A
000182: Jan  8 09:41:49.360: %ISDN-6-CONNECT: Interface BRI0/2/1 is now connected to N/A N/A
000183: Jan  8 09:41:49.368: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
    Cause i = 0x829A - Non-selected user clearing
000184: Jan  8 09:41:49.368: ISDN BR0/2/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
000185: Jan  8 09:41:49.376: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8  callref = 0x01
000186: Jan  8 09:41:49.376: ISDN BR0/2/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
000187: Jan  8 09:41:50.372: ISDN BR0/2/0 Q931: RX <- STATUS pd = 8  callref = 0x01
    Cause i = 0x82E507 - Message not compatible with call state
    Call State i = 0x0A
000188: Jan  8 09:41:50.372: ISDN BR0/2/1 Q931: RX <- STATUS pd = 8  callref = 0x01
    Call State i = 0x0A
000189: Jan  8 09:41:50.452: ISDN BR0/2/0 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x01
000190: Jan  8 09:41:50.452: ISDN BR0/2/1 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x01
000191: Jan  8 09:41:50.452: ISDN BR0/2/0 Q931: TX -> STATUS pd = 8  callref = 0x81
    Cause i = 0x809E - Response to STATUS ENQUIRY or number unassigned
    Call State i = 0x0A
000192: Jan  8 09:41:50.452: ISDN BR0/2/1 Q931: TX -> STATUS pd = 8  callref = 0x81
    Call State i = 0x0A
000193: Jan  8 09:41:51.288: ISDN BR0/2/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000194: Jan  8 09:41:51.288: ISDN BR0/2/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
000195: Jan  8 09:41:51.288: %ISDN-6-DISCONNECT: Interface BRI0/2/0:1  disconnected from unknown , call lasted 1 seconds
000196: Jan  8 09:41:51.292: %ISDN-6-DISCONNECT: Interface BRI0/2/1:1  disconnected from unknown , call lasted 1 seconds
000197: Jan  8 09:41:55.176: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
    Cause i = 0x8090 - Normal call clearing
    Progress Ind i = 0x8288 - In-band info or appropriate now available
000198: Jan  8 09:41:55.176: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
000199: Jan  8 09:41:55.388: ISDN BR0/2/0 **ERROR**: L2_AdvanceVA: TX_ack_queue empty
000200: Jan  8 09:41:55.388: ISDN BR0/2/1 **ERROR**: L2_AdvanceVA: TX_ack_queue empty
Hi Thorsten
It looks better when you have 0/2/0 shut down an the call is arriving on 0/2/1. When the call arrives on 0/2/0 it again seems to appear as two calls using both B channels and the router answers twice. I think you will need to work with your carrier on this and confirm how they have provisioned the BRIs.
In terms of call quality for a connected call, you may want to look at the "compand" command on the BRI port to ensure you are using g711alaw (assuming you are outside the US).
compand-type a-law
HTH.
Barry Hesk
Intrinsic Network Soutions.
6 Replies 6
barry
Level 7
Level 7
Hi Thorsten
This looks a bit strange. It looks like your incoming call is coming in on both ISDN BRI interfaces at the same time - and it is appearing as two calls as far as the UC520 is concerned. If you shutdown one of the BRIs do the symptoms change?
HTH.
Barry Hesk
Intrinsic Network Solutions
Hi Barry.
Thanks for your reply.
I tried to disable the one BRI at a time and they actually have different output in the debug (See attached)
I have two isdn numbers for testing and the uc520 is connected to an NT Box.
The UC is working fine internally and is behind an ASA firewall.. but the phones are ringing for incoming calls and i think this is a matter of ISDN / my config.
The phones are configured to go to a voicemail if no answer and i actually hear the prompt but with great scatter.
Im not sure what the matter is.
Hi Thorsten
compand-type a-law
HTH.
Barry Hesk
Hi Barry.
Just that did the trick.. great
after shutting the 0/2/0 down i now get the voicemail without scatter on both numbers due to the compand command.
I will test the calls tonight and update on the progress.
Again thank you so much for the answer
Thorsten
Hi Thorsten
Great stuff - thanks for the feeback :-)
Barry Hesk
Hi Barry
So happy for your help.. im getting very close.
Actually the NT box was configured to send out both numbers on both channels so now no need to shut interface now and incoming calls works on both numbers.
Status is now as follows :
If i call from the outside im able to answer the call and can hear the outside caller very vell but the caller is not able to hear anything said from the IP phone ? ..
000690: Jan  8 17:37:27.562: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
000691: Jan  8 17:37:27.586: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000692: Jan  8 17:37:28.587: ISDN BR0/2/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000693: Jan  8 17:37:28.603: ISDN BR0/2/1 Q931: TX -> ALERTING pd = 8  callref = 0x81
000694: Jan  8 17:37:29.243: ISDN BR0/2/1 Q931: TX -> CONNECT pd = 8  callref = 0x81
Channel ID i = 0x89
Exclusive, B1
000695: Jan  8 17:37:29.363: ISDN BR0/2/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
000696: Jan  8 17:37:29.371: ISDN BR0/2/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
000697: Jan  8 17:37:29.383: ISDN BR0/2/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
000698: Jan  8 17:37:38.207: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
000699: Jan  8 17:37:38.207: %ISDN-6-DISCONNECT: Interface BRI0/2/1:1  disconnected from unknown , call lasted 8 seconds
000700: Jan  8 17:37:38.239: ISDN BR0/2/1 Q931: TX -> RELEASE pd = 8  callref = 0x81
000701: Jan  8 17:37:38.383: ISDN BR0/2/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
