10-28-2013 05:25 AM - edited 03-16-2019 08:06 PM
I have a problem with the replication between my CUC Pub and CUC subs, is failing.
In Cluster management from CUC serviceability shows in both server
All services are started and running in both server, from CLI i tried to make "utils dbreplication repaircluster" and utils dbreplication clusterrepair unitysubs9 but said that is not accesible.
With utils dbreplication status says is not accesible.
What can be the cause of the problem, any idea?
thanks!
Solved! Go to Solution.
10-29-2013 03:29 AM
Hi ,
the error which u have posted seems to be related to call manager integration.I think u have kept username for CUCM as ccmadmin.
regds,
aman
10-29-2013 03:40 AM
Hi amanso
Yes, i kept username for cucm as ccmadmin, but where is the problem?, in cuc is the same username
10-29-2013 05:44 AM
Hi Ivan ,
you do the settings in UCXN for Cisco Unified Communication Manager and TFTP servers where u enter IP address and order.
why this error is there , no idea?
regds,
aman
10-29-2013 06:12 AM
finally I reinstalled both server and now the db is running properly.
i have two question, may be you can help me again
1- In CUC Subs, there are only 3 options:
Administration, OS and DRS, is this normal? i have never installed pub and subs for a CUC
2- i can not enter in CUC Subs to activate service
8.12 is the IP for CUC Subs. i am trying to enter from Pub
Thanks!
10-29-2013 07:20 AM
Hi amanso
thanks for your help, just waiting for 1 hour all seems is normal, i can enter in service and all option in cuc subs are available.
Thanks for all your help!
regards
