08-26-2008 05:51 PM - edited 03-15-2019 12:51 PM
I have taken over an existing call manager publisher and subscriber ( version 4.1) and require to perform a call manager upgrade on these servers.
I believe it requires the following password in order to do a call manager upgrade. however the only password I have is Adminstrator password.
⢠SQL Server SA Password
⢠LDAP(DC) Directory Manager Password
⢠Private Password Phrase
⢠administrator password
I have done a bit of research and the CCMPWDChanger Tool should allow me to change the DC manager password provided I have the administrator password
but how can I change the sa password and Private Password Phrase if I dont know the existing one?
07-10-2009 12:42 AM
M at same situation. Can you pl send me the tool at nice_chatin@yahoo.com
thanks in advance,
inner_silence
08-28-2008 11:02 PM
Would you be able to send me the script that can resets the DC Directory password to default?
Rachel
08-29-2008 03:01 AM
not sure which script you mean, the one that was mentioned was to find out the old pwd. then you could use the ccmpwdchanger to change it. and sorry, it's a TAC tool.
java
if this helps, please rate
08-31-2008 04:00 PM
I've reset the password now. Thanks.
Kind regards
Rachel
